587,137 active members*
3,273 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > OLDER Haas VF1 and thread milling?
    Dec 2005
    183
    Hi folks,
    I'm considering a used (1992) VF1...white and black enclosure with the rounded edges...and I have a couple of questions.
    First, does anyone know what pin configuration the rotary axis uses? I have a Haas (old!) 5c stepper indexer (black finned motor housing) with a 7 pin output and wondering if this is the correct vintage machine to match it
    Second, it doesn't have rigid tapping. I can get a tapping head for the small stuff, but I need to do a lot of 7/8"-2" diameter threads. So, I'm wondering if this machine can thread mill. It's been years since I've written code for thread milling so I can't remember if there is a specific g code for that or if you can manually combine circular interpolation with a Z move. I will be doing a lot of thread milling, so I'd like it to be reasonably trouble free.
    I have to decide asap so extra points for fast responses! Thanks in advance.
    Mar 2003
    4826
    Sorry, I don't know anything about your 4th axis.
    I would recommend that you go to the Haas website and download the mill control workbooks. There is plenty of good info in there. It may not all apply to an older machine, but it can be better than thrashing in the deep end
    They give an example in there of how to do thread milling with arc commands, using cutter radius compensation and repeated passes. So it is not a special gcode per se, but a special command line.
    Or you could go with a software thread milling solution. There are various thread mill wizards available from some of the thread mill manufacturers. Of course, you have to cut and paste the code. The code is longhand: written out in full so that any controller can cut it with simple helical command movements.
    OneCNCXR4 provides a software thread milling facility that allows you to include the thread milling code right in its nc manager so it is all neatly included in your regular machining files, which makes for easier file-keeping. OneCNC also permits fancier things like 'overlap' on the thread mill pass so as to ensure there is no raised blip on the threads, and an inclined approach/depart so that the thread mill doesn't score the threads as it enters/exits the cut. This can be a concern when the thread mill is large in proportion to the hole it is working within.
    First you get good, then you get fast. Then grouchiness sets in.
  1. G76 Thread cycle Haas SL-30
    By haaszard ahead in forum G-Code Programing
    Last Post: 12-14-2012, 03:26 AM
  2. older haas 200 program limit
    By cherokeechief79 in forum Haas Mills
    Last Post: 10-03-2011, 10:33 PM
  3. Thread Milling
    By Don Clement in forum Tormach Personal CNC Mill
    Last Post: 08-02-2011, 12:48 AM
  4. Replacing rear cooling fans on older Haas VF-0
    By lkenney in forum Haas Mills
    Last Post: 12-20-2008, 05:39 AM
