603,333 active members*
3,847 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > OMAX 2040 WATER JET... BROKEN TILT AXIS AT YEAR 2?
    Apr 2025
    WE BOUGHT AN OMAX 2040 WATER JET BARELY 2 YEARS AGO AN WE STARTED HAVING PROBLEMS WITH THE TILTING AXIS LAST WEEK, FIRST WE WERE TOLD IT WAS THE TX AXIS SERVO CARD, WE GOT IT REPLECED AND BEFORE THAT THE COMPUTER DID NOT ALLOWED US TO MAKE ANY CUT , AFTER REPLACING THE SERVO CARD WE WERE ABLE TO DO SOME CUTTING BUT IT DIDNT TILT FOR 45 DEGREE CUTS... CONTACTED TECHNICAL SUPPORT AND THEN THEY SAID IS A BAD TILT MOTOR... HAS ANYONE BEEN THRU THIS PROBLEM?
    THANKS IN ADVANCE FOR YOUR COMMENTS.
    Jan 2020
    55
    Quote Originally Posted by Sawman46 View Post
    Hi there, can you please take a look at the servo card. This should have LED on it, can you please advise what the flashing pattern is for the LED.
