603,946 active members*
3,426 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Omio rebuilt with UCCNC - problem with CV settings
    Dec 2017
    24
    I have rebuilt my Omio X8-2200L-USB with a CNCdrive AXBB-E ethernet motion controller and then running UCCNC. Prior to conversion I had problems with loosing steps, now it works really nice. However I haven't managed to get the CV settings right, I have experimented and it doesn't jerk in curves as it did but holes sometimes don't get exactly round.
    Have anyone suggestions on the "right" CV settings?
    Mine are:
    Comm. buffer size: 0.1
    Exact stop mode: unchecked
    Constant velocity mode: checked
    Stop att angle degrees> 89
    Look ahead line conunt: 300
    Linear error max. 0.1
    Linear addition length max. 15
    Linear unify lenght max. 35
    Corner error max. 0.03
    Arc radius tolerance 0.1
    Enable softlimits: unchecked
    Softlimits file precheck: unchecked
    Unknown g-codes action: only Ignore checked
    Reset on file load: not any checked
    G41/42 round joints: checked
    Sep 2020
    Re: Omio rebuilt with UCCNC - problem with CV settings
    Are you using fusion 360 for the CAM ?
    I do and when unchecking “smoothing” in the post processing settings or the selected tool path options it’s getting better.
    Excuse my English hope you understood me well
    Dec 2017
    24
    I'm using Fusion 360 so I will try this. Thanks!
  1. Omio X8-2200L-USB problem - fix, rebuild or sell
    By dynaflux in forum Uncategorised WoodWorking Machines
    Last Post: 10-20-2020, 01:09 PM
  2. Unerstanding the UCCNC PWM settings for VFD/Spindle
    By skcncx in forum UCCNC Control Software
    Last Post: 01-11-2017, 09:09 PM
  3. E-Stop not a UCCNC problem
    By Gallchobhair in forum UCCNC Control Software
    Last Post: 03-09-2016, 09:01 AM
  4. UCCNC & Stepcraft 300 problem
    By renenijman in forum UCCNC Control Software
    Last Post: 11-10-2015, 11:46 PM
  5. UCCNC won't install. Any one have this problem?
    By rlrhett in forum UCCNC Control Software
    Last Post: 11-06-2015, 03:12 PM
