Doesn’t sound like the motor is stalling so must be coupler slippage. Tighten up the little coupler connecting the motor shaft to the end of the screw, it clamps on each side so give them both a crank. Given it’s been spinning inside the surface of the coupler could be ragged, might be worth buying a better one to replace them all anyway.
It will look similar to this
