603,777 active members*
4,258 visitors online*
    Oct 2010
    16
    Omitting areas from 3d laser scan
    Good Tuesday all!
    'm looking for anyone that can tell me how to omit areas of an object from a 3d scan. How do i get the scanner to not scan certain areas. The scanner produces STL Files and I have the Hole Filling size reduced to zero. I'v been trying Reflective Surfaces such as Foil, chrome objects etc, There is some patches omitting but its not good. Any Advise?
    Thanks a mill Folks.
    Apr 2004
    5950
    What kind of scanner is this?
    And why do you want to skip certain areas of your model? Shiny surfaces will confuse the laser and create erroneous points, but that's not something people usually want. You'd be better off painting the surface black in areas you don't want to scan, and turning down the laser power a bit (if that's possible with your scanner). Alternatively, you might try pasting some black velvet over the areas you want to skip. But usually what people do is scan the whole model, and cut out the areas they don't (or do) want later on, using a software program.
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Oct 2010
    16
    3d scanner
    i can control the resolution and the sensitivity and the STL hole fill. I need to omit sections before hand as there is no way of measuring the cut out positions on the software. Ill try a dull surface. Thanks!
  1. Laser scan to 3D Solid
    By DragonXtreme in forum 3D Printing / Scanning Software and Hardware
    Last Post: 09-21-2011, 02:46 PM
  2. Scan is reversed with tormach scan software
    By jeffrey001 in forum Tormach Personal CNC Mill
    Last Post: 01-24-2011, 10:49 AM
  3. laser scan tooldiameter
    By gotis in forum Videos
    Last Post: 11-23-2009, 11:52 AM
  4. Laser scan of a neck
    By Meindert in forum Musical Instrument Design and Construction
    Last Post: 01-26-2008, 03:07 AM
  5. i need someone to laser scan a part for me
    By camarogod98 in forum Digitizing and Laser Digitizing
    Last Post: 02-12-2007, 12:56 AM
