588,235 active members*
4,465 visitors online*
Results 1 to 7 of 7
    Aug 2005
    36
    ? on programing
    I have a few hundred parts that need five ops on.c' drill, 2 different size drills, c' bore and tap. I want to set them up in three vises and use fixture offsets. But i want to run all three with c' drill then next tool and so on.will this work.4020 FADAL 88HS CONTROL
    L0100
    xxxx
    xxxx
    xxxx
    m17
    m30
    L0200
    xxx
    xxx
    xxx
    m17
    m30
    etc
    G00 G17 G40 G70 G80 G90
    G54
    t1m6
    L0101
    g56
    L0101
    G57
    L0101
    G54
    T2M6
    L0201
    G56
    L0201
    G57
    L0201
    ETC.
    Apr 2007
    64
    O1* 3 FIXTURE DRILL, TAP, AND C-BORE PROG
    * X0 Y0 CENTER Z0 TOP OF MATERIAL
    * T1 CENTER DRILL
    * T2 .1875 DRILL
    * T3 .201 DRILL
    * T4 1/4-20 CUT TAP (G84)
    * T5 .3125 ENDMILL (C-BORE )
    L100
    G81X0Y0Z-.1R.1F20.
    X2.
    G80
    G0Z1.
    M17
    L200
    G83X2.Y0Z-.5R.1Q.1F20.P.01
    G80
    G0Z1.
    M17
    L300
    G83X0Y0Z-.75R.1Q.1F20.P.01
    G80
    G0Z1.
    M17
    L400
    G84X0Y0Z-.5R.4Q.05F500.
    G80
    G0Z1.
    M17
    L500
    G82X2.Y0Z-.3125R.1F15.P250.
    G80
    G0Z1.
    m17
    m30
    M6T1
    M3S6500
    X0Y0G54
    H1Z.1M7
    L101
    g56
    Z.1
    L101
    G57
    Z.1
    L101
    G0Z3.
    M5M9
    G49Z0
    M1
    M6T2
    M3S6500
    X2.Y0G57
    H2Z.1M7
    L201
    X2.Y0G56
    Z.1
    L201
    X2.Y0G54
    Z.1
    L201
    G0Z3.
    M5M9
    G49Z0
    M1
    M6T3
    M3S6500
    X0Y0G54
    H2Z.1M7
    L301
    X0Y0G56
    Z.1
    L301
    X0Y0G57
    Z.1
    L301
    G0Z3.
    M5M9
    G49Z0
    M1
    M6T4
    M3S500
    X0Y0G57
    H4Z.4M7
    L401
    X0Y0G56
    Z.4
    L401
    X0Y0G54
    Z.4
    L401
    G0Z3.
    M5M9
    G49Z0
    M1
    M6T5
    M3S2500
    X2.Y0G54
    H5Z.1M7
    L501
    X2.Y0G56
    Z.1
    L501
    X2.Y0G57
    Z.1
    L501
    G0Z3.
    M5M9
    X0Y0E0
    G49Z0
    M1
    M6T1
    M2
    Apr 2006
    3206
    I do this all the time, using 4 parts in 2 vises..and I use the fixture offset E 'cause it's easier to recognize, I can number each part with a simple 1,2,3,4, and, well, I'm just used to it.
    It looks something like this:
    ....program definitions.....
    M17
    M30
    G0 X0 Y0 E1
    L101
    G0 X0 Y0 E2
    L101
    G0 X0 Y0 E3
    L101
    G0 X0 Y0 E4
    L101
    G0 X0 Y0 E1
    L201
    G0 X0 Y0 E2
    L201
    G0 X0 Y0 E3
    L201
    G0 X0 Y0 E4
    L201
    G0 X0 Y0 E1
    L301
    G0 X0 Y0 E2
    L301
    G0 X0 Y0 E3
    L301
    G0 X0 Y0 E4
    L301
    G0 X0 Y0 E1
    L401
    G0 X0 Y0 E2
    L401
    G0 X0 Y0 E3
    L401
    G0 X0 Y0 E4
    L401
    M9
    H0 Z0 M5
    G0 G90 X0 Y0 E0
    M2
    Aug 2005
    36
    works great thanks
    May 2007
    1003
    Quote Originally Posted by markjb View Post
    works great thanks
    Which one?
    Aug 2005
    36
    I used the first one
    Mar 2009
    100
    L100
    G0 X0 Y0
    M17
    M30
    E1
    L101
    E2
    L101
    E3
    L101
    E4
    L101
    E1
    L201
    E2
    L201
    E3
    L201
    E4
    L201
    E1
    L301
    E2
    L301
    E3
    L301
    E4
    L301
    E1
    L401
    E2
    L401
    E3
    L401
    E4
    L401
    M9
    H0 Z0 M5
    G0 G90 X0 Y0 E0
    M2
    PUT THE G0X0Y0 in the beginning 0f the subprogram- only to be used by lazy people like myself..
  1. Help on programing the PIC in MM2001
    By DreamerM in forum PIC Programing / Design
    Last Post: 08-30-2011, 01:56 AM
  2. 0-M programing help please
    By venomgrrrl in forum Fanuc
    Last Post: 12-08-2007, 06:51 AM
  3. CNC programing
    By Fryzss in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-27-2007, 04:33 PM
  4. Help on programing the PIC in MM2001
    By DreamerM in forum CNC Machine Related Electronics
    Last Post: 03-18-2007, 11:22 AM
  5. CAM programing
    By kenlambert in forum G-Code Programing
    Last Post: 02-03-2006, 07:03 AM
