587,571 active members*
3,673 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > One axis (z-axis?) computer controlled testing device
Results 1 to 4 of 4
    Mar 2006
    Hey guys I have been lurking around on and off for a few years newer really had the time to get around building any machine.
    Now I need to build a testing device form my PhD project. What I need is a controlled motion in one axis, the necessary movement is no more than 1-2" and I need two speeds. I'm going to do durability tests by repeatedly stretch and unstretch sealant rubber glues and do some stress tests on stucco.
    My idea is to buy a machine vise and add a stepper or servo motor with necessary computer control, hence similar to a z-axis setup. Do you think this is a good idea or do you experienced guys have any pointers for me.
    I need help with everything because I don't know where to start.
    Nov 2005
    30
    I'm relatively new to CNC, but I am an engineer.
    I think you could get what you want with a simple stepper driver and maybe program up a Basic stamp to generate the pulses and the direction logic. You could probably dispense with the driver too but it sounds like you'll be needing a decent amount of force so you'll probably need a chopping driver. You could do the counting mechanically or with the PIC.
    Good Luck!
    Feb 2007
    162
    Try http://www.zaber.com/
    They have motion control products that use a USB port for the interface.
    We used one for stretching silcone samples while mounted in a microscope.
    Scott
    Some of my best finds were in the trash....
    Mar 2006
    The site of Zaber looks very interesting, I will look into it.
  1. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 12:31 PM
  2. Using X axis table moter for knee X axis
    By imatoymaker in forum Uncategorised MetalWorking Machines
    Last Post: 09-10-2007, 01:23 PM
  3. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
  4. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  5. Replies: 9
    Last Post: 06-17-2006, 06:23 PM
