603,936 active members*
2,604 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > One or two pass for a fillet?
Hybrid View
catnamedgoose One or two pass for a fillet? 05-19-2025, 01:40 AM
peteeng Re: One or two pass for a... 05-19-2025, 07:47 AM
    Hi everyone, I am new to CNC machining. My machine is very small, a tormach 440. I was wondering, I have a very small fillet (r:1mm) that is at the floor of my part. I was wondering, should I do this in one pass with a 2mm diameter ball end mill, or do multiple passes with a slightly smaller tool, say 1.8mm diameter? What kind of strategy should I use for the tapered section just above the fillet? Thanks y'all. Not sure if images work in this forum, hopefully the screenshot shows up.
    Attached Thumbnails Attached Thumbnails cfbd0e8f474a68eed84d034bf21bfa14f6f51e6d.jpg
    Jul 2018
    6841
    Re: One or two pass for a fillet?
    Hi Cat - the answer depends on the functional requirement for the surfaces. The bottom fillet can be done with a R1 tool as a finish pass. It could be a bull nose tool so you get the flat and fillet in one. The taper if it is to be for a fit to the sister part then that could be a bit tricky. Need more info on the surfaces functions to answer proper. Peter
  1. fillet
    By jrmach in forum BobCad-Cam
    Last Post: 03-31-2017, 09:34 PM
  2. Fillet Feature
    By lew90nicis in forum Solidworks
    Last Post: 05-03-2013, 06:10 AM
  3. Putting a Fillet in Ti
    By JWB_Machining in forum MetalWork Discussion
    Last Post: 10-19-2011, 03:10 PM
  4. Can't Blend / Fillet this? Why not?
    By kprice1658 in forum Rhino 3D
    Last Post: 08-25-2007, 04:33 AM
