603,311 active members*
2,107 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Open source low cost servomotor controller
Page 1 of 8 123
Results 1 to 20 of 141
    May 2016
    41
    Hey guys,
    I would just like to announce my project, called Odrive. It is an open source high performance brushless servomotor controller, meant to be used with cheap hobby motors. It has 2 axes per board, and allows chaining multiple boards for more axes.
    Let me know if you are interested in development, or want to get your hands on some early hardware.
    Cheers!
    Jul 2012
    106
    Re: Open source low cost servomotor controller
    Now posted design, no posted software, no real description of features and functionality, kinda hard to have interest in a project with no content.
    May 2016
    41
    Quote Originally Posted by websrvr View Post
    Sorry if it was confusing, the details of the project is in the link attached to the word Odrive in the original post. I can give the link explicitly here:
    https://hackaday.io/project/11583-od...-motor-control
    Cheers.
    Jul 2012
    106
    Are you the creator of this work?
    Since the project is being developed elsewhere, why is it being cross-posted here?
    May 2016
    41
    Yeah I am. I thought it would be interesting to reach out to this community too. Especially since I see the type of machines that will benefit the most are heavy machines that need high precision.
    I was hoping to engage in a fruitful discussion on this forum about the project.
    Cheers!
    Jul 2012
    106
    I'm curious to know how you came into the 150A or 75A current specification since all the PCB software I have access too tells me 30A on 4oz stopped copper is the best you can hope for.
    May 2016
    41
    Well, first of all this is peak current, it will for sure not cope with 150A continuous current. Also, I think I can get a fair bit of extra heat dissipation through the heatsink on the mosfets, and down the phase wires. In the end, only testing will show what the capabilities truly are. If it turns out that it is too weak for a number of CNC applications, then it should be fairly easy to increase current capability by just increasing the size of the board and mosfets.
    May 2005
    1397
    As I understand it, v3 doesn't exist yet? Are the design files available for v2?
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    May 2016
    41
    Quote Originally Posted by James Newton View Post
    I have a v3 on my desk atm, see attached picture. I am currently doing some basic tests to make sure that the hardware design is functional. When I have ascertained that that is the case, I will help people get their hands on some v3 boards.
    Nevertheless, all the design files are available here:
    • v3 Firmware is here
    • v3 Board design is here
    • v2 Firmware is here
    • v2 FPGA logic is here
    • v2 Board design is here
    Cheers!
    Jul 2014
    51
    The motors you show are open to chips getting in. Have you built a covering for them and do they not overheat with a cover.
    Feb 2007
    4550
    Macdowswe,
    Very nice, clean looking board.
    Please keep us in the loop, there are many interested users here.
    Welcome to the Zone,
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    May 2016
    41
    Quote Originally Posted by hoecken View Post
    Yeah they are open. I was thinking of making a shroud that houses a motor/encoder assembly, and that has an air inlet with an intake filter, and a fan for forced air cooling. This can probably increase the performance at low speeds fairly significantly since the motors own air cooling doesn't work unless they are spinning at high speed.
    May 2016
    41
    Quote Originally Posted by jalessi View Post
    Macdowswe,
    Jeff...
    Cheers! Thanks! I will keep you up to date.
    May 2005
    1397
    Thanks for pointing to the files... I can't seem to find a Schematic for v3.... what format are those design files in? Is there a pdf or png of the Schematic that I'm missing?
    May 2016
    41
    No problem. The design files are in Altium Designer. There is also a PDF in that folder. Here is a direct link: https://github.com/madcowswe/Servo/b...two_ax_PCB.PDF
    Cheers (:
    May 2016
    41
    Hey everyone,
    There is now an update about board availability and the roadmap for the ODrive features on the project page.
    If you are interested in getting an ODrive board, you should check it out.
    Cheers!
  17. #17
    Jun 2010
    4259
    150A or 75A current through that PCB those FETs, those wires and those connectors?
    Really?????
    Cheers
    Roger
  18. #18
    May 2016
    41
    Quote Originally Posted by RCaffin View Post
    Really?????
    Cheers
    Roger
    Yeah ;D
    This is not a continuous rating, but peak rating. The continuous rating will be significantly less than that.
    But it is the peak rating that is important, as the the torque peaks only during the first bit of acceleration in a move, and the last bit of deceleration. If you are using the torque to push continuously into a workpiece, the system should be dimensioned such that you would use much less current for that.
  19. #19
    Oct 2008
    11
    Im impressed! This is a wonderful project! About time someone did this! You could also use this for force feedback in flying and racing simulations!
  20. #20
    Aug 2015
    142
    There is a way to put a encoder in this config , or i don't see one .
    Thanks .
Page 1 of 8 123
  1. Replies: 31
    Last Post: 08-24-2015, 10:03 AM
  2. Smoothie CNC controller, Open Source.
    By Rolf_K in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-15-2015, 07:41 PM
  3. CNC Controller with Arduino - open source
    By Christian Knüll in forum Open Source Controller Boards
    Last Post: 12-22-2012, 10:46 AM
  4. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  5. BEST Open source Controller ?
    By Seventeen in forum Open Source Controller Boards
    Last Post: 09-22-2005, 12:27 AM
