588,084 active members*
4,905 visitors online*
Page 12 of 20 21011121314
Results 221 to 240 of 394
  1. #221
    Dec 2010
    226
    Thanks to Miata2k for all of the help identifying issues with F-Engrave (on and off forum).
    I have posted a new version F-Engrave V1.22 on my web page.
    Changes in Version 1.22:
    - Fixed three bugs associated with importing DXF files
    - Fixed bug associated with cleanup calculations
    - Changed minimum allowable line spacing from one to zero (adds more flexibility for users).
    (I have to think more about how to keep the bounding box info displayed. That feature is no included yet.)
    Scorch
  2. #222
    Dec 2010
    226
    Stop the CW/CCW Insanity!
    F-Engrave V1.30 is now available Here: F-Engrave Download
    Here are the highlights:
    - F-Engrave now can determine which side of the loops in a DXF design need to be cut when v-carving. Previously the input needed to be formatted so that the loops in the design were clockwise or counter clockwise to determine whether the inside or outside of the loop was cut.
    - A new “V-Carve Accuracy” setting. This new setting can be used to ignore small features in a design. This is especially useful for small DXF design imperfections which result in bad v-carve tool paths. You can also get some speed improvement by increasing this value allowing F-Engrave to ignore tiny features.
    A side note: I plan to continue to post updates here but I am also posting them and some other stuff on the Scorch Works Blog and on the Scorch Works Facebook page.
    Good luck,
    Scorch
    Scorch
    www.scorchworks.com
  3. #223
    Sep 2005
    371
    My bad...
  4. #224
    Dec 2010
    226
    The link is there. Your browser may have the page cached so you might need to reload the page (F5).
    @Vogavt I'm glad to see my naming convention is consistent enough that you could make your own link
    Scorch
    Scorch
    www.scorchworks.com
  5. #225
    Sep 2005
    371
    Oops!
    So it is!
    I'll remove the direct link. This way folks will see the whole page at your site instead.
    I just thought I could help you out in the interim.
    Sent from my DROID RAZR using Tapatalk 2
  6. #226
    Dec 2010
    226
    F-Engrave Version 1.32
    F-Engrave Version 1.32 is now available on the F-Engrave Web Page. This release includes a few minor items that I have had backlogged for a while. The items are listed below.
    - Added limit to the length of the engraved text included in g-code file comment (to prevent error with long engraved text)
    - Changed number of decimal places output when in mm mode to 3 (still 4 places for inches)
    - Changed g-code format for G2/G3 arcs to center format arcs (generally preferred format)
    - Hard coded G90 and G91.1 into g-code output to make sure the output will be interpreted correctly by g-code interpreters.
    Scorch
    www.scorchworks.com
  7. #227
    Jan 2007
    1795
    I found a few linx..
    I think there are many more..
    one of them autocad dwg with hatched areas..
    next is a dxf
    third is an ai file..
    sure you can open ..
    Attached Files Attached Files
  8. #228
    Jan 2013
    6
    I wanted to thanks Scorch for the programs. Still in the build stage of my machine but have been playing with F-Engrave and am impressed! I have checked out countless free and otherwise programs and yours is one I'll stick with. Just want to encourage you to keep doing what you do.
    Mike
    Sent from my Le Pan S using Tapatalk
  9. #229
    Dec 2010
    226
    Thanks, Good luck with your CNC build.
    Scorch
    www.scorchworks.com
  10. #230
    Feb 2011
    4
    Hi Scorch
    My latest little project with F-Engrave thanks for great program, the border I got from craftmanspace.com, free patterns, borders and 3D models etc.
  11. #231
    Sep 2005
    371
    Awesome Chinook!
    It looks to be pyrographed. Or did you do the wood burning after the v-carving?
    I've been thinking about setting up something for that purpose to enable a hot tip to do that sort of thing. But there are so many variables to consider.
  12. #232
    Feb 2011
    4
    Thanks Vogavt nice to share.
    I discovered F-Engrave about a month or so ago, it is the most intuitive and simple Cam program I have come across and only found this thread about a week ago.
    No pyrography it's all calved with V-Calve in F-Engrave I used a 45deg v cutter with 2mm dia gave +- 2.4 mm on Z. I then raised my Z touch off +- 1mm above the work plane and cut the Cleanup Path with the same 45deg V bit and no V Cleanup. The resultant calved timber is left rather rough so on rubbing with varnish the roughness soaks up a lot more varnish and is left a lot darker.
  13. #233
    Sep 2005
    371
    So there's no staining? Just pure varnish?
    To clarify: deeper cuts (-2mm) for outlines and shallower cuts (-1mm) for cleanup from the zero of the work surface. Correct?
  14. #234
    Feb 2011
    4
    Correct and using the same v bit for cleanup
    Cheers
  15. #235
    Dec 2010
    226
    F-Engrave V1.33
    I uploaded version 1.33 of F-Engrave, it is available on my web page. (F-Engrave 1.33)
    Changes in Version 1.33:
    - Added option for scaling input image height as a percent of the input values (rather than imputing the height as a length unit). This new feature should help people that combine more than one image together in a project. The new option is "Set Height as %" which allows scaling the input image by a percentage rather than setting a size(in or mm) for the height. Setting the height % to 100 will result in the image being the same size as the imported DXF file.
    - Fixed batch mode...again. (I should really check that it is working before each new release)
    ** Thanks to Captain Chaos for the helicopter picture posted below I always like to see things that people have cut using my programs. **
    Scorch
    www.scorchworks.com
  16. #236
    Dec 2010
    226
    F-Engrave With GRBL
    For users of GRBL I put together a Blog Post describing the issues with F-Engrave and the settings needed to generate g-code that will work with GRBL. Below I listed the settings needed (without the long explanation from the blog post).
    F-Engrave settings needed to generate g-code compatible with GRBL:
    - Select the “Disable Variables” box in the F-Engrave Settings window
    - un-select the “Enable Arc Fitting” box in the F-Engrave Settings window
    - Use F-Engrave Version 1.34 or higher
    Scorch
    www.scorchworks.com
  17. #237
    Feb 2013
    39
    Re: Open Source V-Carving
    There's just one thing I'm not getting.
    How does one determine what size a carving is going to be?
    I see the option for setting it the text width to 100% --- 100% of what?
  18. #238
    Sep 2005
    371
    There's a boundary information field at the bottom on the screen.
  19. #239
    Sep 2005
    371
    Oh and the text width at 100% is normal size of character. Greater than 100% would stretch the characters out (elongate it) and less than 100% would compress them.
  20. #240
    Dec 2010
    226
    Quote Originally Posted by WillAdams View Post
    One ore thing to add to Vogavt's answer: The text size is driven by the text height input. For a given text height the width of the text is determined by the shape of the characters. Changing the width input deforms the characters shape to be narrower or wider.
    Scorch
    www.scorchworks.com
  1. Open Rail - open source linear bearing system
    By milatary56 in forum T-Slot CNC building
    Last Post: 06-09-2012, 02:07 PM
  2. OPEN SOURCE BLUEPRINTS?
    By denis6902 in forum Open Source CNC Machine Designs
    Last Post: 03-05-2010, 02:04 PM
  3. Open Source Cad Cam
    By kch in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-30-2007, 12:51 AM
  4. CNCPRO Open Source
    By Mits in forum Spanish
    Last Post: 06-07-2007, 05:04 PM
  5. Open Source Gecko 201 Look A Like?
    By pminmo in forum Open Source Controller Boards
    Last Post: 11-07-2004, 05:51 AM
