588,243 active members*
4,329 visitors online*
IndustryArena Forum > CAM Software > Visual Mill > Opening .dwg files in VM 5.0
Results 1 to 6 of 6
    Sep 2004
    Hi all. I'm new at VM and CAD/CAM in general. I'm currently taking a class on CAM which features VM. For the life of me I can't open any files that I've created in AutoCad (2004). I asked my professor but since we just started the class he told me we would cover this later. Can someone help me with this? I can't wait to get started. Thanks in advance.
    Cheers -
    JT
    Mar 2003
    35538
    Try saving as ACAD2000 format .dwg
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Sep 2004
    Thanks for the response ger21. I've tried to save the file as all the file types AutoCAD will allow and none work. I can't understand why it would be that difficult to even open a file.
    Mar 2003
    35538
    Does it seem like it opens, but there's nothing there? Or does it give you an error message?
    Gerry
    Aug 2003
    26
    If you're trying to export curves from acad export them as .dxf , for solids export as .stl --- in VM open solids as .stl , for curves import regions .
    Jan 2004
    3154
    When saving the dxf as well make sure to save it as version 2000 or earlier. You should have no problem.
    www.integratedmechanical.ca
  1. How to view iges files
    By Hack in forum Uncategorised CAM Discussion
    Last Post: 05-07-2011, 09:03 AM
  2. CAD Files for Machine Design
    By Hack in forum DIY CNC Router Table Machines
    Last Post: 12-12-2004, 09:58 PM
  3. DXF or PLT files
    By signIT in forum DIY CNC Router Table Machines
    Last Post: 07-01-2004, 10:57 PM
  4. Visual Mill 5.0
    By ninewgt in forum Visual Mill
    Last Post: 02-06-2004, 05:00 PM
  5. .bin Files
    By sundara in forum Uncategorised CAM Discussion
    Last Post: 09-13-2003, 11:33 PM
