603,386 active members*
3,061 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Operation Data - At Op End
Results 1 to 6 of 6
    Apr 2003
    416
    I am using Gibbs 5.1 to post a lathe file. I want to add a few lines of code at the end of a operation. I enter the code by
    -Right click on the operation tile
    -Select Operation Data
    -Enter code in the box At Op End
    G0X7.0
    M01
    -I then reprocess the operation.
    I can not get the post to include my new lines.
    Is there something else I need to do?
    Bill
    Apr 2003
    1876
    The literals that it requires must be in quotes.. try
    "G0X7.0
    M01"
    or maybe
    "G0X7.0"
    "M01"
    HTH
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1876
    BTW, if you go to HELP and turn on Baloons, it will give you good explinations of the boxes you put the mouse over.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    416
    Thanks Matt,
    I knew about the balloon help, but I didn't read it closely enough. (I missed the part about quotes).
    I am never sure if I'm missing something with Gibb's or it just does not work. If you try to copy and paste a line of code into At Op End, it does not work. Is this right?
    Bill
    Apr 2003
    1876
    Quote Originally Posted by wjbzone
    Thanks Matt,
    ...I am never sure if I'm missing something with Gibb's or it just does not work. ...
    Bill
    That was always a problem when I was using it too. I think they've got a lot of those things 'fixed'
    ,,,If you try to copy and paste a line of code into At Op End, it does not work. Is this right?
    Bill
    I don't remember trying that when I was using it. Did you try CTRL+V as well as right clicking and selecting PASTE?
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    416
    I found that I can paste a line of code in the Op end/Op Start. I just have to hit the ENTER key after I paste for it to be saved.
    Bill
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 08-09-2024, 08:56 PM
  2. Visual Basic Controller Project
    By dwwright in forum Visual Basic
    Last Post: 04-16-2016, 10:31 AM
  3. CNC Glossary
    By cncadmin in forum Community Club House
    Last Post: 03-09-2008, 09:08 PM
  4. Cutting bit questions
    By cncadmin in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2004, 10:12 PM
