603,894 active members*
3,675 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > optimal setting for eldorado cnc setup.
Results 1 to 4 of 4
    Sep 2004
    152
    Basicly Trying to find what the best motor settings for mach 2 or 3. The cnc motors and controler are the ones that are from shoptask. ANy help would be great.
    http://www.rainman229.com
    Apr 2006
    4
    Shoptask motor settings
    Here are the settings from my Shoptask Tri-Power with acme screws and
    the shoptask CNC package. The step were determined via DRO.
    motor config (MILL) step pins / direction pins
    x Axis 2 / 3
    steps 40000
    velocity 24.366
    accel 2
    y Axis 4 / 5
    steps 40000
    velocity 22.41
    accel 1
    z Axis 6 / 7
    steps 63899
    velocity 3.72
    accel 0.823956
    motor config (LATHE) step pins / direction pins
    x Axis 4 / 5
    steps 40000
    velocity 24.366
    accel 2
    y Axis Not used
    z Axis 2 / 3
    steps 63899
    velocity 23.286
    accel 2
    Yours should be close to this.
    Feb 2005
    487
    what are you using steppers or servos??
    To ball park steppers:
    How many steps per rev the moter has (usually 1 step = 1.8 deg), X any micro step settins, x your drive ratio, x your tpi (if using imperial screws). will give you how many steps it takes to move 1 inch.
    Servos:
    Encouder count per rev. x (line count if you have one), x drive ratio x tpi.
    then tell it to move 1 inch, measure what it really moved, devide what you told it to move by what it moved. take that number and multiply to your current steps/unit. (BTW: move back to 0 befor you ajust your steps per inch). Repeat until you moving 1 inch each time. Then go back to 0, and tell it to move 6 inches (on X or Y), measure what it moved and divide that into 6, and it will give you a longer averaging error over travel. If you want to really get it down. then, command a full length axis move, measure and repeat above.
    Scott
    Sep 2004
    152
    sorry guys been a little too busy to check in on this.
    I'm running steppers
    right now x and y are at 8000 seems to be right on the money. Z is in the 5000 somewhere
    My biggest problem is not so much the steppers them selves. It's more the max speed. i guess i would need to toy with that on my own.
    trying to figure out the max depth i could cut with a desent speed.
    My max speed at the moment is at .900 sec and i think it should be able to handle .100 pass with no problem.
    Note I mostly work with 6061 alum and some plastics.
  1. Specs for cnc small parts - Shoptask Eldorado
    By pfarber in forum Shopmaster/Shoptask
    Last Post: 12-09-2006, 06:13 PM
  2. Setting z
    By bbergami in forum G-Code Programing
    Last Post: 10-01-2006, 02:21 PM
  3. Finding optimal components for servo drive
    By Xerxes in forum CNC Machine Related Electronics
    Last Post: 08-22-2006, 11:29 AM
  4. Setting up VM5
    By dneisler in forum Visual Mill
    Last Post: 03-12-2006, 04:50 PM
  5. What is your opinion on optimal table height?
    By Madclicker in forum DIY CNC Router Table Machines
    Last Post: 12-03-2005, 05:23 PM
