588,571 active members*
6,754 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Optimum BF20L CNC conversion using the Smooth Stepper
Page 4 of 31 2345614
Results 61 to 80 of 602
  1. #61
    Feb 2006
    174
    Hi there,
    regarding Smoothstepper time out, I used to have those issues, but after the latest plug-in updates I am tempted to say they have gone away. Have also had some problems with the ftdi driver, but these are taken care of by a grounding wire between my laptop and the controller case.
    Your description of the troubles you can run into with "run from here" are very familiar!
    Lars
  2. #62
    Jun 2011
    Quote Originally Posted by LN-JET View Post
    Hi there,
    Lars
    Hi there Lars yeah and in my case I'm using the USB cable to power my SS so I don't have to worry about any grounding issues and yup Greg also told me to update to the latest SS plug-in and update to the development version of Mach but in my case even in idle Mach kept crashing with timeout issues so it appears that for some PC’s the latest plug-in works then….good to hear……..since I’ve had SS time out issues I also read that Greg has released for sale the Eithernet Smooth Stepper and this definitely has solved the dreaded “Ground Loop” issue completely too….!
    And for anybody else too here’s the links to my queries and to the solutions offered too from other members…
    Warp9 Tech. Design - Home of the SmoothStepper
    Development version of Mach .056 Z axis crashing
    Smooth Stepper just stops communicating with Mach3
    Eoin
  3. #63
    Jun 2011
    oops just found out that the link for Warp9 in my previous post only works if you can log in... sorry......but there's nothin new in that thread from what you can read in the Mach Forum posts....
    :cheers:
    Eoin
  4. #64
    Jun 2011
    Talking
    I know you can buy them pretty cheap but just a little project simply to see if it worked.......I ruined my lovely turned finish with the needle file pity..
    Attached Thumbnails Attached Thumbnails Image1357.jpg   Image1361.jpg   Image1363.jpg   Image1365.jpg
    Eoin
  5. #65
    Dec 2010
    55
    ... wrong thread
  6. #66
    Jun 2011
    Quote Originally Posted by Flexo! View Post
    ... wrong thread
    no problem
    Eoin
  7. #67
    Feb 2012
    Hi Mad Welder
    very good topic. :cheers:
    I hope you have more things to develop, because I will follow
    I have a mill similar to BF20.
    And soon I intend to convert it into a CNC
    Tchau
  8. #68
    Jun 2011
    Quote Originally Posted by edimar View Post
    Hi Mad Welder
    Tchau
    thanks for that you're welcome and there's a bunch of other builds/conversions too just select the Benchtop Machines link above and check out the PM25, G0704, WMD etc these are all similar machines.
    Eoin
  9. #69
    Jun 2011
    For the past while I've been learning my CAD/CAM (Rhino…….bloody heck this surfacing software is seeeeerious….!) package and Mach so no build progress updates till now but here’s one drawing I thought was pretty cool and if anyone wants the GCode just post
    Attached Thumbnails Attached Thumbnails 17022012121.jpg   17022012125.jpg   17022012126.jpg
    Eoin
  10. #70
    Jun 2011
    ok a few updates, originally when planning my build I had intended to increase my Y axis, hence the larger support table, drip tray and enclosure and I had factored in adding approx 200mm to the Y axis by purchasing another base Machines Tools, Beltsaws, Machine Tools Ireland, Millennium Machinery, Used Machinery for at the time I was quoted (€200euro/262USD XE: (EUR/USD) Euro to US Dollar Rate) this would be a similar Y axis extension to what Hoss had done on his X2 Projects 6 , but unfortunately finances have dictated my progress again so using what I had as stock, this is what I have chosen to do….. and more to follow hopefully tomorrow
    Attached Thumbnails Attached Thumbnails 10022012024.jpg   10022012025.jpg   10022012033.jpg   10022012036.jpg
    Eoin
  11. #71
    Jun 2011
    oh yeah and one of the reasons I'm including extra Y axis travel is because I'm including a 5th axis in the future and this will move the spindle head too.
    Eoin
  12. #72
    Jun 2011
    and also a new updated enclosure click the drawing in the attached file and left click and hold and you can rotate it to get 3D imagery
    Attached Files Attached Files
    Eoin
  13. #73
    Jun 2011
    oh and can someone tell me how to add a photo within a text post and another photo and text etc...as opposed to just attaching loads of photos as I've been doing as it will allow me better captions to explain progress and how to avoid problems too with similar builds....thanks
    Eoin
  14. #74
    Sep 2010
    87
    If you type some txt, then do
    [/img]url link to image here[img]
    and some more txt....that should do you
  15. #75
    Jun 2011
    thanks Rikk and yeah I tried that but I mustn't be doing it correctly so when I select the image icon and get the little popup window asking to enter the URL and as I don't have a website to link the pics to what do I type in here?? is it just the standard C/documents and settings/mypictures/folder etc....?
    Eoin
  16. #76
    Sep 2010
    87
    You need to have the photo's hosted on a site to be able to do it that way, loads of free ones about. I use Photo Sharing. Your Photos Look Better Here. | SmugMug you do pay for it but it's very cheap and extremely good.
  17. #77
    Jun 2011
    yeah I thought so cheers
    :cheers:
    Eoin
  18. #78
    Jun 2011
    Can some one explain the advantage of AC/VFD over DC spindle motors
    I'm back again looking for advice can some one explain the advantage of AC/VFD over DC spindle motors please?
    I'm lookin to upgrade my spindle motor and change to belt drive too. My Optimum 850watt stock motor just simply hasn't got enough umph for face milling...!
    Am I correct in understanding that basically the VFD 'part' converts single phase to three phase to power a larger HP motor?
    also am I correct in understanding that VFD can also induce huge amounts of electrical noise? and can lots of electricial noise cause lost or incorrect steps in the Stepper Motors?
    Eoin
  19. #79
    Mar 2009
    1114
    One of the biggest advantages is efficiency and reliability. The VFD can take single phase and convert it to three phase on lower horsepower motors, but that's not the purpose of a VFD. The VFD gives you an infinite amount of speed control between 0 and whatever speed you decide run your motor at. Also if you go with a sensorless vector drive, low speed torque is greatly increased due to the way it monitors motor load. However they come with a price. DC speed controls just can't compare.
    Another feature that I personally like is the flexibility you have when setting up a VFD. There's usually digital I/O's, analog, and the list goes on. If your interested in going AC/VFD check out automationdirect.com. Amazing products for reasonable prices.
  20. #80
    Jun 2011
    Cheers for that Starleper1 and the link too, I am kinda leaning towards the VFD route it's just.... oh boy another learning curve to understand the additional wiring and connection and I/O's......I have the C32 bob from CNC4PC CNC4PC and I may be able to wire direct from that but I must read up more....
    any one got a simple wiring diagram that I could use to help me understand more.
    Eoin
  1. Optimum 180x300 CNC Gang tool conversion
    By belli in forum Mini Lathe
    Last Post: 11-25-2015, 10:51 PM
  2. Optimum BF20 G0704 Conversion
    By Winnfield in forum Benchtop Machines
    Last Post: 08-07-2011, 12:16 AM
  3. Smooth stepper
    By dnelso in forum Charter Oak Automation Support Forum
    Last Post: 08-04-2009, 05:07 PM
  4. Optimum BF20L CNC conversion
    By JanHenning in forum Vertical Mill, Lathe Project Log
    Last Post: 03-11-2009, 05:09 PM
  5. OPTIMUM BF20L mill, z-travel exactly from table height ?
    By vroemm in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2009, 10:01 PM
