588,492 active members*
4,490 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Optimum BF46 Vario spindle getting hot and tool holder sticking
Page 2 of 2 12
Results 21 to 25 of 25
  1. #21
    Apr 2005
    862
    Re: Optimum BF46 Vario spindle getting hot and tool holder sticking
    I can't view the video for some reason, but if it is a clattering sort of sound it is likely to be the quill splines rather than the gearbox. If you pull the quill down a bit and then check the noise and it goes away or changes significantly then that would be it.
    LongRat
    www.fulloption.co.uk
  2. #22
    Feb 2013
    21
    try this for the video link
    https://www.youtube.com/watch?v=yU7PD8AB-zM
  3. #23
    Apr 2005
    862
    Hm, that doesn't sound like I was expecting. Most likely something else then. Just check it does the same thing with the quill lowered. If the sound goes away then it isn't a bearing problem I would suggest.
    LongRat
  4. #24
    Feb 2013
    21
    I have come to realise its actually some vibration in the drawbar. I changed the collet chuck and all of a sudden the noise was happening at a different RPM and yet it was consistent to that initial RPM while I only changed collets. More on this as I solve this.
  5. #25
    Nov 2018
    Hey
    it is okay for the spindel to get 60-70´C
    if you losen the upper nut to mutch is will result in bad finish,
Page 2 of 2 12
  1. Optimum BF46 CNC Conversion.
    By george@brisbane in forum Benchtop Machines
    Last Post: 01-06-2019, 07:39 AM
  2. Optimum BF46 CNC conversion with Kflop and Teknic servos.
    By harishom in forum Benchtop Machines
    Last Post: 06-25-2016, 05:18 AM
  3. Replies: 6
    Last Post: 02-19-2015, 02:08 AM
  4. Info on Ballscrews for Optimum BF46
    By MrBean_pm in forum Linear and Rotary Motion
    Last Post: 11-01-2013, 06:57 PM
  5. Optimum BF46 Centroid retrofit
    By yolklab in forum Benchtop Machines
    Last Post: 04-01-2012, 04:33 AM
