588,025 active members*
5,034 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > Ordered a Torus Pro-S yesterday.
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Mar 2011
    480
    And it just get better....
    Got my Hertel 2 flute 1/2" end mill in and gave it a run. I have to say I'm really impressed for $12.00 end mill !. I ran several cuts progressively faster each pass to see how the spindle load held up. I couldn't find a torque curve for the motor, so I went with 75% of max speed (4500 rpm). So these cuts were .5" DOC .2" step over. I ran from 25 to 40 IPM with a slower/light finish pass at the end. How much more can she take ?.
    http://www.youtube.com/watch?v=CzRli_x_mic
  2. #22
    Jun 2007
    3735
    You can set the display on the VFD to display current. Monitor code d-1 I believe for the C300 VFD.
    That will give you a better idea of how much grunt you have in reserve.
    Examine the chips under high magnification, and if still well formed you can probably push it harder.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  3. #23
    Jul 2006
    525
    Quote Originally Posted by LAKESNAKE View Post
    torus - YouTube
    Further, how did it sound performing that cut? (edit-- hah. i'm an idiot. I'll turn sound on and hear for myself.)
    That's about exactly what I was looking for, and it certainly looks adequate.
    Whens that tool changer coming out?
  4. #24
    Feb 2011
    605
    Looks sweet.
    With HSMWorks you can have lots of fun with adaptive clearing. With a 3 Flute Carbide tool I've found that around .25" DOC and .20" WOC at 100 IPM is pretty sweet as well. With the servo version you can link your rapid moves at 500 IPM as well.
    This video of my machine is full of stuff not to do, but at 2:26 there is roughing like described above at 100 IPM. The initial profile is also done at 90 IPM and at one point gets into a 4 HP cut due to my poor stock cutting.
    3 things not to do while machining - YouTube
    PM-45 CNC conversion built/run/sold.
  5. #25
    Jun 2008
    1082
    I said (almost) the exact same thing (I threw in an expletive for emphasis) when I used the wrong height parallels one time. That was exciting!
    The worst* thing is: the scar on the jaws is a constant reminder.
    * actually, this might also be the best thing.
  6. #26
    Jun 2007
    3735
    Hmmm. Measure twice, cut once.
    I did that to my magnetic chuck with the surface grinder.
    Lucky mine was low on HP.
  7. #27
    Feb 2006
    7063
    Quote Originally Posted by jid2 View Post
    Kinda scary how much the head moves around when doing those high-speed cuts....
    Regards,
    Ray L.
  8. #28
    Mar 2011
    480
    Been there done that (more times than I would like to admit). I did find my aluminum end mills do a good job on steel clamps though
Page 2 of 2 12
  1. Just Ordered A Torus Pro
    By SCzEngrgGroup in forum Novakon
    Last Post: 10-18-2013, 10:00 AM
  2. Got my 145 yesterday- 7-15-10
    By tunaahelper in forum Novakon
    Last Post: 07-18-2010, 12:59 AM
  3. it worked yesterday (540)
    By turbothis in forum Gecko Drives
    Last Post: 11-29-2009, 11:12 PM
  4. Tried to buy a HF X2 yesterday. Failed!
    By tooManyHobbies in forum Benchtop Machines
    Last Post: 03-12-2008, 12:00 AM
