603,308 active members*
2,795 visitors online*
    Apr 2008
    48
    OSAI 10- Tool Change Error
    I am trying to get an older CNC running that has an OSAI 10 control. I am able to execute G code files. The main issue I am facing is that the CNC goes into an error whenever a T command is executed, either through the G code, or MDI. The OSAI control displays the following error:
    Error 23/401- Process :01
    New Tool Request Failed
    in the HICAM2 window it displays a similar error:
    99-152 Error T programmed process
    This seems to hang up at around this point in the macro (I do have the macro if that is useful)
    #PMT=0 ; Change from T like macro to normal PLC function
    T(HI)
    #PMT=1 ; Come back to T like macro
    #(DLY,1);
    Any Ideas?
    Thank you!
    Jun 2023
    Re: OSAI 10- Tool Change Error
    hi hope you are good
    i have an osai 10 series
    only when ia make an program for drilling it shows me an error NC 066 part program not found
    can anny one help me
  1. M6 tool change error
    By joesmith2022 in forum Auto Tool Changer
    Last Post: 12-29-2022, 11:21 AM
  2. Replies: 0
    Last Post: 04-14-2021, 05:06 PM
  3. M06 tool change error
    By lee-gib in forum Fanuc
    Last Post: 04-11-2016, 06:20 PM
  4. OKUMA MB 66-VB Tool Change Error
    By Jesse_Daniels in forum Okuma
    Last Post: 09-04-2015, 09:04 PM
  5. Tool change error
    By mattpatt in forum Fadal
    Last Post: 06-17-2010, 01:18 AM
