587,663 active members*
3,153 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP 5020L--Alarm 110A SDU 1
Results 1 to 9 of 9
    Jul 2010
    We are trying to get running an LB25 lathe with the OSP5020L Control; we can not get past the following error: Alarm 110A SDU 1
    The VAC does not appear to be getting any power...there are no green or red light on the board. When we try to reset the VAC by holding the ALM/RST on the lower front area of the board when we restart...nothing.
    Alarm manual is all but useless, "check No. 8 bit 5"
    Thanks for any suggestions.
    Jun 2008
    372
    Basically it is saying there is an issue with the SDU Spindle Drive Unit
    Apr 2009
    1262
    You should have some kind of lights on the drive unit. Carefully check your power supplies and incoming voltages as well as circuit breakers. Use the electrical diagrams for the power on circuit as a guide.
    best regards,
    Mar 2009
    1982
    not only circuit brakers. VAC drive unit has it's own fuses. These could be blown. Ask electrician for help, if You will blow just replaced fuses. Short circuit somewhere. Power transistor (IGBT) modules, most likely.
    Apr 2006
    825
    Quote Originally Posted by Algirdas View Post
    Finally... Al you have actually stated that an ELECTRICIAN is to be used to check something!
    What is wrong Mr Al? Are you feeling ill or something?
    You normally resort to telling people to just jump in where ordinary mortals should fear to tread! i.e. where deadly voltages are concerned... and check this or that.
    Wow, are you finally figuring out that a qualified person should ALWAYS be used when dealing with this type of area?
    About damn time...
    Nov 2010
    Talking
    Does that mean you dont use a wet finger and a rusty nail in Oz ??
    Apr 2006
    825
    Not so much as a "Rusty" nail as in a Bright Shiny one!
    Inserted carefully with wet hands whilst standing in a puddle of water... of course!
    The "rust" would just make things a little difficult to get the juice flowing
    Sep 2010
    Right!! Crivens when ye need to put someone in immediate danger ya don' wan te complicate things, jus' stick your tongue to the leads. When someone uses a fokain chair to whack you off cause your locked up, then you KNOW where te start.
    But I ave a cencern aboot Al's post, does that mean he isn't Omnipotent? Because according te the wee darlin' he is in fact all knowin'.??? In't he cute with his wee yellow ears mates?
    Mar 2011
    23
    Re: OSP 5020L--Alarm 110A SDU 1
    Hello
    Did you get sorted this problem with vac drive ?
    I have same problem and local tech can't repair
    Any sugestions?
  1. Replies: 1
    Last Post: 10-05-2013, 09:16 AM
  2. Replies: 3
    Last Post: 09-10-2013, 07:54 PM
  3. LS30-N 5020L Alarm-A 106
    By phuongnt in forum Okuma
    Last Post: 08-20-2013, 08:46 AM
  4. Okuma OSP 5020L Alarm 205-3 X Axis
    By Mark Pelnar in forum Okuma
    Last Post: 10-06-2009, 09:34 AM
  5. OSP 5020L
    By MKATool in forum Okuma
    Last Post: 04-06-2008, 08:08 PM
