588,064 active members*
5,052 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > osp 5020L monitor went out!!
Results 1 to 13 of 13
    May 2009
    91
    i have an okuma cadet lathe with an OSP 5020L... machine was running then all off a sudden the monitor went out... all the buttons and controls work just fine.. its just the screen dont work no more.... anyone know what happen? blown fuse?, monitor toast? video card?... any help on trouble shooting the problem would be sweet!!! thanks
    Mar 2009
    1982
    call some CRT TV technician. You need to swich off the machine and disassemble CRT box. Optimistic case You just clean there. Maybe scan transistor blown, maybe just contact of transformer bad.
    Dec 2008
    3136
    Sometimes the monitors tend to lose the contrast ( fade ) when on the way out
    Did you have such a indication ??
    or
    did someone just turn the screen OFF as a joke ???
    May 2009
    91
    any crt tech can take a look at it? it doesnt have to be someone familiar with a cnc?
    Feb 2007
    592
    Check that panel switch!
    Quote Originally Posted by Superman View Post
    or
    Exactly - be sure the CRT off button is not active - if you toggle the button give the CRT time to come up - its not instant on.
    Worse case - Okuma has come up with a LCD retrofit since the OEM CRT's are no longer available. I prefer the look of the CRT's but the LCD's work just fine.
    May 2009
    91
    i played with the switch and still nothing.... my operator said he didnt notice the screen getting darker or anything like that...
    Sep 2006
    24
    We had the same thing happen a few weeks ago. Our maintenance man opened the panel and reset a breaker and it came back on. At least that's what he told me he did.
    May 2009
    91
    a breaker in the back of the machine or inside behind the monitor?
    Aug 2009
    3
    I really think the 24v is being dragged down! Is there alot of vibration while cutting? The problem you have is sometimes doing this not happening all the time or is the control completly off and will not boot
    May 2009
    91
    the control works.. but the monitor wont come on at all
    Aug 2009
    3
    Well then your crt went out. I would be careful working around the tube monitor let someone experienced dig into it. You might be able to get a tv repair shop to fix your problem. Like someone said before okuma has a retrofit flatscreen that you replace it with, really easy to install!. Really nothing else you can really do, other than what i said. I was thinking your control was turning off and on whenever, sorry.
    Sep 2007
    6
    Quote Originally Posted by Oti View Post
    I have the same problem right now! Do you know wich breaker reset???
    May 2009
    91
    The problem turned out to be a blown CRT I went to a local tv repair shop and 200 bucks later I had a working monitor
  1. 5020L startup problem
    By rick kroeze in forum Okuma
    Last Post: 07-31-2009, 08:36 PM
  2. 5000L-G vs. 5020L-G
    Last Post: 07-19-2009, 02:11 AM
  3. With Okuma BL-2 50A and OSP 5020L
    By marfranso in forum Okuma
    Last Post: 06-05-2008, 09:13 AM
  4. OSP 5020L
    By MKATool in forum Okuma
    Last Post: 04-06-2008, 08:08 PM
  5. Okuma OSP 5020L
    By al-108 in forum Okuma
    Last Post: 03-18-2008, 09:17 PM
