603,348 active members*
3,149 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > OSP 700L DELETE PROGRAMS
Results 1 to 6 of 6
    Dec 2008
    JUST PURCHASED A USED LB10M. CAN'T SEEM TO FIGURE OUT HOW TO DELETE PROGRAMS...
    ALSO, HAS ANYONE HAD PROBLEMS WITH COMMUNICATION? I CAN SEND PGMS TO THE DESKTOP, BUT NOT FROM THE DESKTOP TO THE MACHINE...
    Feb 2003
    349
    Quote Originally Posted by flywkr View Post
    edit, Delete Prog-Name, if it is protectet, use it with ;c
    u have no Disk Drive?
    Dec 2008
    79
    for deleting , edit>delete *>write - this should delete all programs one by one
    or
    edit>init>write -delete all programs in one shot
    for the transfer , br sure that your file got th $progname.min% at the start and the % at the end and every character got to be in CAPS, the osp700 dont support small character
    on the controller . edit>PIP>read>write or edit>PIP>readTT>write
    hope this works for you, data transfert is a bit tricky on okuma controler
    Apr 2006
    825
    If you use DELETE * you will delete all programs WITHOUT confirmation.
    If you use DELETE *;V you will get the Delete Confirm message for each file.
    Dec 2008
    79
    Quote Originally Posted by broby View Post
    not on the osp700L , delete * and the machine will ask you "delete progname.min Y/N" at each program
    Apr 2006
    825
    Ah, We have a couple of OSP7000 controllers and I thought that it was still applicable, however, always willing to concede that it may be different on the OSP700.
    If not, wel you you now have the method I have used to get the machine to confirm the delete or not.
  1. OKUMA CROWN OSP 700L DRIVE UNIT
    By yorkshire grey in forum Servo Motors / Drives
    Last Post: 01-20-2010, 02:59 AM
  2. DELETE
    By g-codeguy in forum MetalWork Discussion
    Last Post: 08-06-2008, 02:36 PM
