587,092 active members*
2,939 visitors online*
    Mar 2009
    OSP-P200M question
    I want to make a program that checks every tools status and then using the MSG-function display it on the screen.
    But I have run in to some trouble, I want to use a variable in the MSG function.
    Something like this:
    (G120 is a macro to check tool status)
    Code:
    VC1=0
    N9999
    VC1=VC1+1
    G120 T=VC1
    IF [VC200 GT 0] GOTO N9998
    IF [VC1 LT 200] GOTO N9999
    N9998
    MSG(T=VC1 is not ok)
    I can't get it to work...
    Is there a way to do this?
    Thank you in advance and I apologize for my bad grammar.
    Robin
    Feb 2009
    202
    MSG Function
    try this:
    VNCOM[1]=1
    MSG(MISSING DATA "D")
    MISSING DATA D is the msg to display
    Dec 2008
    3122
    The main problem is the message, it is a comment and will be printed onto the screen as stated, it has to be outside the comments so that it can be parsed by the control
    Modified a little, so if the tool cannot be identifed by the message, VC1 is the bad tool. VC200 and ERROR checking should be removed and placed in the G120 macro, as this sets and controls that variable (VC200).
    VC1=1
    NCHK
    G120 T=VC1
    VC1=VC1+1
    IF [ VC1 LE 200 ] GOTO NCHK
    GOTO NEND
    NEND
    M30
    ( this should be in G120 macro )
    IF [ VC200 GT 0 ] GOTO NERR
    NERR
    VNCOM[1]=1
    MSG T=VC1 ( is not ok) ( not sure if it will work, but this is what you want )
    M00 (TOOL is not ok)
    NMSG
    NEND
    M30
    What part of "status" are you checking ?
    Is it the D offset for each tool ?
    There may be another "system" variable that can be directly checked ?
