Hi all...new to this forum.
I need some help with an old LC-20 with the 5000L control (not a 5000L-G or 5020L)...can't get the RS232 to work...no comms with laptop when punch or read. I read through some of the threads but couldn't find info on this vintage 5000L control.
I have other LC-20s, 30s, an LB-15 and two LT-15s with 5000L-G and 5020L controls. Communication works fine with them so I am assuming my cable's pin configuration is good. I also used the same DNC configuration as my other Okumas except changed the baud rate to match this control
The optional parameter word and parameter bits only go up to 32...there is no page two for them. I have a manual but it doesn't tell me anything past parameter #10 of the optional parameter word. Info on optional parameter bit is even worse.
I did the following as recommended by Gossiger (local Okuma reps):
I changed parameter 1 to 1 (optional parameter word) and parameter 10 to 300 (baud rate...which is a max of 350!).
I changed parameter bit 1 to - 00011011
parameter bit 12 to - 00100010
So far, no matter what I've done i get the same result...no communication. When I hit READ then WRITE the cursor just continues to blink and the screen does nothing...doesn't even time out and I waited 15 minutes. i have to turn the control off then back on to get it to clear.
When I try to punch all I get is a punch error.
Anybody have any advice? A Gossiger tech will be here tomorrow but he already told me on the phone it may be difficult to get this to work.
Thanks for any help.
Brad
