can anyone tell me where to find info on what can cycles i can use on a osp5020l thanks for your support.
dont have a manual but ive noticed in edit mode there is a igf button dont know anything about igf can you help me.
If the machine has IGF it will have most of the canned cycles. IGF is awesome, easy, and powerful. You need to find someone local to teach it to you. Well worth it.
The okuma control is very powerful. Quick one to get you started.
Turn a 2 step diameter from 4 inch material.
Step1 is 1.5" diameter 1.25" deep in Z,
Step2 is 2.5" in diameter 2.75" deep in Z. Both diameters will have a radius of 0.060"
$TEST.MIN%
G0X20Z20(SEND TURRET TO POSITIVE LIMITS IN X AND Z)
G50S2000(SET SPINDLE MAX RPM)
N1T010101G97S1200M3M8(TOOL, CONSTANT RPM, SPINDLE ON, JUICE ON)
G0X4.1Z.1(RAPID .100 ABOVE STOCK DIAMETER, .100 FROM FINISHED FACE)
G96S500(CONSTANT SURFACE SPEED)
Z.025(2 ROUGH PASSES ON THE FACE BEFORE ROUGHING THE OD)
G1X-.05F.01
G0Z.1
X4.1
Z.003
G1X-.05
G0Z.1
X4.0(START POINT FOR OD ROUGHING CYCLE)
G85NLAP1D.1F.01U.02W.003(ROUGHING CYCLE)
D=DEPTH OF CUT DIAMETRAL
F=FEED IN INCHES PER REVOLUTION
U=FINISH STOCK X AXIS DIAMETRAL
W=FINISH STOCK Z AXIS
NLAP1 G81(LONGITUDINAL TURNING CYCLE)
G0G42X1.2(AT LEAST 2* TOOL NOSE RADIUS BELOW START POINT FOR .060 RAD)(1.5-.12(RAD)-.0625(TOOL RAD)=1.2 IS PLENTY)
G1Z0.
G76X1.5L.06(AUTOMATIC TANGENT RADIUS OF .060)
G1Z-1.25
G76X2.5L.06
G1Z-2.75
X4.0
G40(CANCEL CUTTER COMP)
G80(END CANNED CYCLE)
G0X4.1
Z.1G97S1200
X20Z20
M01
N2(FINISH FACE AND OD)
G0X20Z20
G50S2000
T020202G97S1200M3M8
G0X4.1Z.1
G96S800
X1.6Z0.
G1X-.05F.004
G0Z.1
X4.1
G87NLAP1F.002(EXECUTE A FINISH PASS AT .002 FEED THROUGH CANNED CYCLE NLAP1)
G0X4.1
Z.1G97S1200M9
X20Z20
M02
thanks for the help throttle jockey i hope i can help you some day.
That's just a little taste. If you want to get into some more complex stuff let me know. Like I said the Okuma controls are super-powerful.
Cheers
