Good evening. I am setting up a new machine and I have the following doubt. I use TNG with Mk3 / 9 + an original Planet output board, connected via IDC cable. The manual says that the IDC cable and terminal connections should not be used at the same time. The motor of my spindle has an electric servo fan that must be powered separately, so with the M3 / M5 commands I need to start both the spindle and the electric fan. I would therefore need to parallel two relay outputs. Can I make a jumper on the terminals of the output board - for example 1 & 2 - to have the simultaneous closing of two relays on the board while maintaining the IDC connection between the controller and the output board?
