588,375 active members*
8,284 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Output Feature Name in Post Processor
Results 1 to 4 of 4
    Oct 2008
    65
    Using feature_name_comment and system_comment as listed below does not output any comments. Using V24, Build 546. I'm sure this is a simple fix, but I am not able to get any of the other variables to output either; pass_name_comment, feature_pass_names_comment, pass_name or feature_name.
    1000. Version Information = Version Month Day Year? "9.1 02 15 2010"
    3. Tool change.
    force_no_add_spaces
    comment_start,"****** TOOL CHANGE *** ",t," ***",comment_end
    system_comment
    default_add_spaces
    n,"M06",t
    n,work_coord,"M25"
    n,absolute_coord,rapid_move,force_x,xr,force_y,yr, rotary_xyr_angle
    n,rapid_move,length_offset,s,spindle_on
    output_rotary_angle
    Thanks in advance for any help.
    Steve
    V28/29 4x Pro, Haas VF-3SSYT, Haas SL-30
    Apr 2008
    1577
    Make sure this box is selected. If it is, you may need to post a file and your post processor to see what's going on.
    Oct 2008
    65
    Thanks SBC Cycle, I did look there, but assumed it only applied to the User Comments. Again, thanks!
    Steve
    Apr 2008
    1577
    No problem! I admit, it puzzled me for a second
  1. Replies: 8
    Last Post: 07-18-2012, 10:51 PM
  2. MC post processor output format
    By garyong in forum Post Processors for MC
    Last Post: 04-14-2011, 07:36 AM
  3. Post processor output in conversational?
    By klrskies in forum BobCad-Cam
    Last Post: 07-02-2010, 12:27 AM
  4. Eagle CAM Processor output - Mach3 Size issue
    By deleteallusers in forum G-Code Programing
    Last Post: 05-02-2007, 03:14 PM
  5. Feature Cam Post For 04 Tl-1
    By DATTAMAN in forum Haas Mills
    Last Post: 02-04-2005, 04:27 PM
