603,316 active members*
2,479 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Output radius instead go I and K
Results 1 to 5 of 5
    Mar 2008
    377
    Unhappy Output radius instead go I and K
    I am trying to see how to post the radius instead of (I and K ) on the lathe does anybody know how to do it
    If so can u please show me please.
    Nov 2006
    490
    The settings are located in the "control definition" dialog that you find under the settings tab.
    Mar 2008
    377
    Thank u for the reply
    But where under the settings do u change it.
    Dec 2009
    80
    Hi! Click on "Arc" to the left and then under "Arc center type" you can select "Radius" for your working plane.
    Attachment 219900
    Mar 2008
    377
    Thank u my brother that really helps when u put up that picture.
  1. Small radius good Large radius bad
    By K2Developmentab in forum Fadal
    Last Post: 09-26-2013, 07:26 PM
  2. Replies: 1
    Last Post: 05-15-2013, 08:52 AM
  3. Replies: 7
    Last Post: 10-06-2011, 04:43 AM
  4. radius output from postprocessor
    By peters1980 in forum EdgeCam
    Last Post: 02-09-2011, 11:36 AM
  5. Radius to end of arc differs from radius to start?
    By Jamy in forum LinuxCNC (formerly EMC2)
    Last Post: 08-23-2009, 05:28 AM
