587,647 active members*
3,198 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Laser Engraving / Cutting Machine General Topics > Output size is wrong on normal engrave after using rotary attachment
    Sep 2018
    6
    Hoping someone can help me out
    I am new to using my laser machine (bodor 1390 150w c02)
    I was doing ok with normal engrave (sucking so bad trying to cut thats another story), yesterday I thought I would try out my rotary engraver, got it plugged in and attempted to engrave some glasses, didnt work smashed them, anyway, today I want to go back to normal engraving on wood, and its not doing so to scale.
    I use RDworks, can anyone step me through how I reset the system to be normal again.
    and also, can anyone help with good reference to using the rotary machine I got with it?
    Images attached to show what i mean
    thank you for your help.
    Kylee
    Attached Thumbnails Attached Thumbnails 42505270_500439040471478_3051960613296144384_n.jpg   42534149_395604617641990_8703297277365583872_n.jpg
    Jan 2016
    22
    Re: Output size is wrong on normal engrave after using rotary attachment
    Check under the "Output" tab to make sure that you have the "Enable rotate engrave" unchecked for normal engraving.
    Sep 2018
    36
    Quote Originally Posted by jacquard View Post
    Kylee
    Ohhhh Kylee, you poor thing. You will need a long vacation before all of this is over. Fortunately, this one is easy to fix. If you messed around with the user settings, then I would recommend you just restore the original user settings. You should have a copy of them on your thumb drive. Just go to the User Tab in RDWorks, click Read, click Open and then locate the User Setting.RDUSet file on your thumb drive. Finish by clicking Write and you should be good to go.
    If you tell me which rotary device you are using, I will sent you a similar .RDUSet file with the proper rotary settings. Rather than go in and change parameters each time you want to engrave something cylindrical, I find it easier to just have two separate User Settings and simply switch between them using the steps above.
    Danny
    Engraving Machines Plus, Corp.
    (321) 821-7774
    Melbourne, FL
    alternative text
