586,383 active members*
3,752 visitors online*
Results 1 to 15 of 15
    Nov 2015
    260
    Own GUI buttons with menu functions
    Hello.
    I have a touchscreen and would like to add my own buttons to the GUI, with which menu functions such as "measure / corner" can be activated.
    Is that possible, and if so how?
    Aug 2020
    131
    Re: Own GUI buttons with menu functions
    A Description can be found at
    https://planet-cnc.com/adding-user-t...-tng-software/
    Add the following to the txt for the toolbar you want to add the button to and you get a Inside Corner button
    Code:
    cmd: "Machine.Measure.Inside_Corner" "Inside"
    Klaus
    Nov 2015
    260
    OK. That worked.
    Now I would like to make small drawings for the buttons in the SVG. What resolution is needed there?
    Mar 2017
    1312
    SVG is vector file. Resolution does not apply.
    Nov 2015
    260
    Yes, I thought so too.
    But then QCAD does something wrong when exporting to SVG. The .svg from QCAD are very small as buttons.
    Mar 2017
    1312
    Send SVG to my email and I'll examine it.
    and include your profile zip file.
    Jun 2017
    143
    When using Inkscape I found that I had to set a custom document size of 50px by 50px for it to display properly in TNG. I found this by looking at the svg files provided and that was the page size used in those.
    Nov 2015
    260
    Quote Originally Posted by PlanetCNC View Post
    Thanks.
    I also tried inkscape. The buttons are not centered there.
    I also downloaded some from the Internet, they are too small or not centered, or both.
    Attached Files Attached Files
    Mar 2017
    1312
    Please export and send me your profile zip so that I can test with your configuration.
    Nov 2015
    260
    Thank you for the effort. I've got it now with QCAD.
    I had to enlarge the objects exorbitantly.
    I can live with the current situation.
    Nov 2015
    260
    Hello
    Code:
    -->  work fine:  cmd: "Program.Edit_..." "Edit" imagechange="true" stroke=1.1
    --> do not work:  cmd: "Machine.Start_Options.Start_From_Selected_Line" "SFSL" imagechange="true" stroke=1.1
    What am I doing wrong?
    Mar 2017
    1312
    Nothing, it is my error. I used incorrect name:
    cmd: "Machine.Advanced.Start_From_Selected_Line"
    but I fixed it and in next version it will be:
    cmd: "Machine.Start_Option.Start_From_Selected_Line "
    Nov 2015
    260
    Yes, I have now found out. I looked in the language-text files.
    Nov 2015
    260
    How can I make a separator line.
    Mar 2017
    1312
    or
    test which one works best for you
  1. Replies: 4
    Last Post: 11-25-2012, 01:37 AM
  2. where is the menu soft key?
    By getdog in forum Fanuc
    Last Post: 09-12-2012, 06:11 PM
  3. BIN and BCD functions
    By sinha_nsit in forum Fanuc
    Last Post: 02-25-2009, 11:09 PM
  4. M functions
    By graphity in forum HEIDENHAIN -> GENERIC
    Last Post: 09-04-2008, 09:11 AM
  5. BP functions
    By Mr. Technical in forum Bridgeport / Hardinge Mills
    Last Post: 11-07-2007, 06:02 AM
