588,487 active members*
6,200 visitors online*
Results 1 to 14 of 14
    Aug 2005
    8
    oz-in torque on dc motor
    Hello,
    This is my first post on this forum and I’m not sure if this is the correct section to post but it seem to fit.
    I would like to know about DC motors. I need to find a motor for an application I’m building. I need a DC motor to run on as little volts as possible, the diameter should be less than 1 inch, the motor should have an RPM at about 120 240 RPM.
    I found all these requirements in some motors the only thing I don’t understand it the Torque or oz-in torque. Can someone explain oz-in torque and how this value would be would be used to determine a motor?
    thejoe
    Aug 2005
    86
    Could you rephrase your question? Torque is the "strength" of the motor, like if it can put out 1 oz-in of torque (one ounce of force at a distance one inch from the shaft), you could stop it with your fingers, but 1000 oz-in of torque you could not stop.
    Torque is highest at 0 RPM ("stall"), and lowest at maximum RPM (no-load), and is roughly linear in between. So if you put a load on a motor, it slows down.
    I have a feeling, though, that this is not quite what you are asking.
    Aug 2005
    8
    What I want to do is connect a 1" long by 1\4" round shaft adapter to a dc motor shaft. The end of this shaft could spin any number of attached objects like a golf ball, solid brass wheel, etc.
    I'm trying to finger out how much weight or torque a motor would need to turn these objects without stopping?
    Aug 2005
    8
    here is the motor I'm looking at.
    http://www.lynxmotion.com/Product.as...&CategoryID=11
    Aug 2005
    86
    If the thing you are spinning is centered on the shaft, it takes very little torque to just make it spin in the air. That little motor is plenty to spin a golf ball.
    Aug 2004
    2849
    Well on the motor you show with 4.6 oz-in of torque as the stall torque.....this basically means that if you had a 1 inch long level attached to the end of the motor that anything greater then 4.6 oz would cause the motor to stall out (not turn).
    Aug 2005
    86
    I'm pretty sure the 5 oz-in is the "rated" torque. That is almost certainly the popular "60:1 Copal" motor, about which more data here:
    http://robotcombat.com/marketplace_ant_motors.html
    50 oz-in stall torque.
    Aug 2005
    8
    This is a simple drawing of what I want to make.
    http://users.mn.astound.net/jokersdesign/steel.jpg
    The shaft adapter is a custom machine milled peice that I had a local company make.
    The steel balls that screw on could range diameter and the weight could be from 1/4 ounce to 4 ounces.
    So if a DC motors specifications says Torque = 4.86 oz-in, then the motor should be able to spin the a steel ball with a weight of 4 ounces at X RPM?
    Robert
    Dec 2003
    24221
    One other factor to consider is the inertia factor which is calculated to provide whatever acceleration/deceleration is required.
    Al.
    Albert E.
    Aug 2004
    2849
    Good point Al. I noticed that they recommend that you not hit the stall torque because you'll damage the gear box....so, I suspect that you can get it going, but you may have a hard time reversing direction or stopping at any number close to the stall torque.
    Aug 2005
    1622
    I am reasonably certain you would need to calculate the moment of inertia for a given mass to qualify a torque quantity. That can get complex for irregular shapes.
    Do a web search for calculating moments of inertia. Your question relates to many principles of several foundations. The mass and how it relates to inertia in order to obtain a torque value to move that mass. Once it is motion the dynamics change.
    Here are a few:
    Solid Mechanics-Dynamics
    Inertia to torque calulators and charts
    Angular acceleration
    Hope this helps some.
    DC
    Dec 2003
    24221
    There are also many free downloadable programs where you can plug in the motor/load parameters in to calculate inertia, Kollmorgan, Allen-Bradley Electro-Craft Seiko-Denki etc.
    Al.
    Albert E.
    Aug 2005
    1622
    Quote Originally Posted by Al_The_Man
    Al.
    I wouldn't expect those would work for micro-motors with gear reduction would they?
    I suppose if you had a load profile of the motor anything is possible.
    DC
    Aug 2004
    2849
    yes, but you can determine what you can do pragmatically.....
