603,872 active members*
3,343 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Painting/restoring CNC machine
Results 1 to 1 of 1
    Jun 2021
    28
    I am in the process to refurbish an old CNC machine, the mechanical and electronical parts are all okay now, I also re-implemented the tool changer (the accuracy as far as I have checked is around 0.01mm); so now I am heading to the optic part.
    Now the question is which paint / coating should be used inside a machine? I am aware that the enclosure has to be removed completely for this process of course.
    There is a company nearby doing powder coating, is that used with machines nowadays?
    Also what kind of material / glass should be used for the window? It does not seem to be simple acrylic (and I would be concerned about hot chips hitting it).
    thanks.
