603,874 active members*
4,438 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Pallet unclamped Alarm 180 - machine used to have APC
    Hello,
    My company has a haas VF4 manufactured in 2000.
    It used to have an APC but that was not purchased at the auction apparently. We can reset the alarm but it returns quickly. The pallet is clamped. The switch is made but it still throws the alarm. All I can figure is that our issue is tied to the fact there used to be an APC. We’ve torn it apart down to the slides and put it back together with no change.
    Oct 2023
    3
    Re: Pallet unclamped Alarm 180 - machine used to have APC
    Looking at https://www.haascnc.com/service/trou...ing-guide.html it has the following:
    Setting
    382 Disable Pallet Changer
    Maybe try changing setting 382 to disable the pallet changer?
  1. APC locked (Función APC arm up y pallet block) SH-630
    By Crespo in forum Mori Seiki Mills
    Last Post: 10-21-2022, 05:25 PM
  2. APC pallet change
    By Busmathias in forum Benchtop Machines
    Last Post: 03-18-2020, 02:58 PM
  3. Replies: 5
    Last Post: 07-26-2019, 09:21 AM
  4. Replies: 1
    Last Post: 01-26-2016, 05:36 AM
  5. Not able to use machine with APC battery alarm
    By DanielBamek in forum Fanuc
    Last Post: 06-23-2015, 07:34 PM
