Ok,it may only take you all a minute or two to realize I probably dont know what Im talking about-but-.I have an older Ge 1050 control that uses a parallel
tape reader.Its signal output is 10.5 v,not 5v like a traditional p port on a pc.I would like to use a B&B serial to parallel converter to bypass the tape reader,a BTR,if you will.How would one amplify the 5v signal from the B&B to 10.5v for the ge tape reader port?I also need to fool the ge into thinking it see's a sprocket signal timed with the first data track with in 1.6 ms.it can be done as commercially available BTR's have this feature.I have a BTR,but it doesnt work and the MFG wont support it-any suggestions?
"If it was easy,everyone would do it."
