588,206 active members*
4,191 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Parallel port card??
    May 2011
    65
    Angry Parallel port card??
    I decided to overhaul a desktop cnc I put together a few years back, I replaced the steppers with bigger ones, replaced the Hobbycnc pro board with a new Gecko 540 and replaced the power supply along with new drive screws bearings etc. Now it appears from reading the posts my computer will not work with the Gecko drive because I have an add on parallel port card. This problem came to light when I tried to find a way to change it over to epp config. I am about tapped out in the dollar situation, is there any alternative. The card I have is a Rosewil. Works great with hobbycnc board.
    Any help or suggestions would be welcome.
    Thank you
    Terry
    Regards, Terry Howson
    Dec 2005
    80
    Hi Terry
    The PCI version of this board should work if you can set it to address (Hex) 278 and IRQ 7 .... although I doubt if the latter is used.
    I doubt these are defaults.
    Regards
    Richard
    May 2011
    65
    Thank you for the reply and suggestion, on reading somemore I am convinced my card will not work with Gecko, so I bit the bullet again and ordered the one from pmx that advertises it has been modified especially for Gecko drives.
    Terry
  1. Parallel port add-in card.
    By Drools in forum Gecko Drives
    Last Post: 06-27-2012, 06:40 PM
  2. PCI parallel port card
    By Smooth90 in forum LinuxCNC (formerly EMC2)
    Last Post: 12-13-2011, 05:17 PM
  3. Which PCI parallel port card?
    By bead in forum CNC Machine Related Electronics
    Last Post: 07-03-2010, 07:32 PM
  4. PCI 1 port parallel card
    By noyloj in forum Machines running Mach Software
    Last Post: 12-03-2009, 12:22 AM
  5. PCI Parallel Port Card
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2008, 04:03 AM
