I need to rotate a part program 180 degrees but the coordinate rotation parameter is not turned on. Does anybody out there know what parameter it is?? Thanks for your help.
PM sent.
Stevo
Hi Stev01
I have the same problem. We have en old Matsuura running a Fanuc 6MB controller. I am machining a curved slot and wanted to use the G68 command to pattern it around a circle. The controller does the first slot but then when it reaches the line:
G68 X0.0 Y0,0 R45.0
it gives an error 010
According to the Programming book this error means that it is an invalid code for this controller, but it describes G68 in the book. Any ideas?
Use the Plane G17 with this line...it will work..
Kirit Rupala
Machine Rebuilding & Sales
G68 is an option. The book describes everything that is possible to do on the machine.
Somebody may pm you the option parameter.
Thanks kirit
ill give that a go
Thanks for the info sinha_nsit
