588,202 active members*
4,208 visitors online*
Results 1 to 6 of 6
    Jul 2007
    25
    PARAMETER LIST FOR MAZAK
    I heard that it is possible to download parameter lists from the MAZAK site. Is it true ? and where do we go to download them because I haven't seen it on their site.
    Denis Paradis
    [email protected]
    Sep 2006
    126
    what your Mazak model?
    Jul 2007
    25
    AJV 3560 1987 CAM M2 controller. I need the parameter list for the pallet changer. We can't get the pallet to change.
    [email protected]
    Dec 2007
    300
    Smile Pallet changer AJV35/60
    You should just need to M Codes to do a manual pallet change. They should be in the M Code list in the operator manual. M71 calls pallet #1 M72 calls pallet #2, some machines use M911 and M912. If you need a complete listing of the M Codes let me know, I could send it to you.
    Mar 2005
    988
    What is exactly is the problem with your pallet changer? Are you stuck in some weird spot? Command doesn't execute? It stops in mid-change? It doesn't start at all?
    If you're stuck, you also have solenoids on that machine you can force without parameters. But this all depends on what your "pallet changer problem" is...
    It's just a part..... cutter still goes round and round....
    Mar 2008
    175
    Quote Originally Posted by Denis13 View Post
    Are machine parameters or cutting conditions on their website?
  1. parameter list 3tc
    By R.thayer in forum Fanuc
    Last Post: 09-17-2011, 08:12 PM
  2. parameter list
    By Drye-123 in forum Fanuc
    Last Post: 06-17-2008, 05:56 AM
  3. Need Parameter List and alarm help with Seicos 21L
    By tjenkins in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-08-2008, 05:00 PM
  4. parameter list for PUMA 5 machine
    By nmistry in forum Fanuc
    Last Post: 09-06-2007, 03:53 AM
  5. help with fanuc 18i parameter list
    By bob1371 in forum Fanuc
    Last Post: 11-06-2003, 03:24 PM
