603,365 active members*
3,589 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport / Hardinge Mills > parameters for a 1988 Bridgeport Interact 412V Heidehnain TNC151 P control
Results 1 to 4 of 4
    Sep 2005
    254
    Hi , I was wondering if anyone has the machine parameters for a 1988 Bridgeport Interact 412V Heidehnain TNC151 P control . I recently bought the machine and it had problems when i got it. ( I knew this ) I was just looking at the parameter list i got with the machine and it is for the TNC 155 control.
    I'm not sure if they are the same or not.
    Jan 2005
    1121
    i 'think' the parameters for the 155 are extended, for graphics etc, but that the baseline parameters are valid. Look at a manual for the 151 and 155 and confirm that this is the case
    Sep 2005
    254
    HI Gus , Thanks for the Reply !!!! I think it's strange that the parameter list i got with the machine is not a match to the control. I don't think bridgeport would do this.....then again you never know......? I was hoping to find a list for the TNC151 so i could compare them.
    Dec 2011
    63
    Hi ... I've just purchased an 1988 Interact with the Heidenhain TNC 151. Attached are the factory machine parameters.
  1. bridgeport interact 1 lost parameters
    By thomasmc in forum Bridgeport / Hardinge Mills
    Last Post: 02-02-2015, 10:35 PM
  2. Bridgeport interact 412V
    By jovanov in forum Bridgeport / Hardinge Mills
    Last Post: 05-10-2011, 12:43 AM
  3. Bridgeport Interact 720 parameters
    By M.G.Machinist in forum Bridgeport / Hardinge Mills
    Last Post: 01-08-2010, 01:04 AM
  4. Series 1 Bridgeport w/TNC151 control
    By Mark Canaan in forum Bridgeport / Hardinge Mills
    Last Post: 12-03-2008, 10:45 PM
