I need some help with parameters for the G70s canned cycles on Mazak Powermaster with Fanuc 6T. Tried programming a can cycle for OD rough and get 007 Alarm, Decimal point. Went through program and everything looked as it should i'm assuming. Did a decimal after every whole number (4.), unless it should be (4.0). How can I tell if the parameters are on for this type of programming. Any info would be appreciated.
