587,733 active members*
2,850 visitors online*
    Dec 2006
    310
    Part Count in Fanuc 21 MB
    Dear All
    We have got Mitsubishi VMC with Fanuc 21MB
    Part count, which appears at the bottom of Position Screen, is not getting updated
    Please let us know on how to activate this so that at the end of ever Auto cycle, part count will increase by 1
    Best Regards,
    M. Rishikesh
    Aug 2011
    2517
    check parameter 6700 bit 0 (PCM) & 6710
    6700 Bit 0
    M code that counts the total number of machined parts and the number of
    machined parts
    0 : M02, or M30, or an M code specified by parameter No.6710
    1 : Only M code specified by parameter No.6710
    6710
    M code that counts the total number of machined parts and the number of machined
    parts
    [Valid data range] 0 to 255 except 98 and 99
    The total number of machined parts and the number of machined parts are
    counted (+1) when the M code set is executed.
  1. Replies: 6
    Last Post: 01-31-2012, 04:34 AM
  2. What is important part count or utilization
    By chrisryn in forum MetalWork Discussion
    Last Post: 07-15-2009, 09:06 AM
  3. Encoder Count
    By Billiam in forum Servo Motors / Drives
    Last Post: 03-16-2009, 03:20 PM
  4. A light-weight table/bearing assembly with a low part count.
    By greybeard in forum Linear and Rotary Motion
    Last Post: 11-10-2005, 12:16 AM
