Re: Part Dimensional Expectations With Taig Mill?
The stock spindle is a multi pulley belt drive. Top speed is 10000rpm, but there are much slower speeds. The motor is only 1/3HP if I recall, but you can have either high rpm and low torque or low rpm and high torque. Within its power range it will cut just about anything. Some work hardening alloys may be problematic just because it doesn't have enough power to take a big enough chip, but most can be cut if you plan around what you have.
Bob La Londe
http://www.YumaBassMan.com
