588,190 active members*
4,494 visitors online*
Results 1 to 5 of 5
    Parts for 4x8 Plasma Table
    Hey guys,
    I have been lurking for some time now and finally started getting my parts together. I am for the most part copying Dnelso's build. Before I make a costly mistake I would like to get some inputs on some of the parts I have chosen. And I am a newbie so if I ask a stupid question, that's why!
    Here are the parts and prices I have been quoted so far, as well as the source.
    Steel for the build will be around $600 and I am making the table 9' x 5' so I can come off the cutting area a bit.
    If the space is blank that is because I haven’t gotten that far!
    I have a few questions. I am looking at Anaheim Gear for a reduction unit. They are high priced but still within the budget $250ish for the direct drive and $500+ for the 90deg. angle.
    The problems I am having are the gear reduction ratio to get and the resolution change due to backlash. There inline unit stated a backlash of (12 arc-min) and the 90 deg. unit is (22 arc-min) are these acceptable #s for Plasma? Also the torque ratings, everything I read is showing a 3:1 reduction is the best?
    I am hearing 20* pitch on the rack?
    Thanks for the help!!
    Oct 2006
    30
    Yes 20* on the rack. Also check Cncrouterparts.com for their shuttles that have a 3:1 reduction. I've got a slew of parts from them for my new build and I'm pleased with what I got. I'd say the backlash on those reduction boxes won't affect much with plasma just due to the nature of plasma in general.
    I ordered from more gear and instead of longer pieces they recommended just buying 6' racks and piecing them together on the table assuring me that it wasn't a difficult task. Saved quite a bit in shipping.
    Anyway looking forward to seeing the build.
    Quote Originally Posted by Jeep07 View Post
    Thanks for the help! I talked to the ladies at Moore Gear and she told me about Cncrouterparts! I think I am going with there 3:1 reduction set as well. It's a lot cheaper than the planetary reduction sets!
    Jul 2006
    1256
    Good to forget about the gear boxes.
    You need 2-5' rails and 8 blocks
    Larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Quote Originally Posted by lgalla View Post
    Larry
    Thanks for the tips Larry!
  1. Precision Plasma LLC 2' x 3' DIY Plasma Table
    By rchacich in forum News Announcements
    Last Post: 08-26-2011, 12:05 AM
  2. Trying to Building a fold up plasma table from plotter parts
    By rogerfries in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 09-25-2010, 10:49 PM
  3. Precision Plasma LLC 5' x 5' CNC Plasma Table
    Last Post: 11-10-2009, 05:08 PM
  4. Need some parts Plasma cut
    By pimpbike in forum Waterjet General Topics
    Last Post: 03-26-2007, 05:49 AM
