603,960 active members*
3,485 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > Path Issues - Which Software???
Results 1 to 1 of 1
    Nov 2007
    9
    PLEASE SEE THE ATTACHED ILLUSTRATION OF THE ISSUE.
    OK as you can see from the illustration provided I have one block of foam which requires the left set of axis to cut one set of shapes (smaller) and the right set of axis to cut the other (larger) shapes.
    Also note that the shapes from left to right vary as the left hand shape is square and the right hand shape is a star. Both of these have different perimeter lengths. I hear that Foamworks would have trouble with this as the number and placements of the points would vary too much and by using Foamworks it would cause the shape to be cut incorrectly. At first i thought that increasing the feed on the right hand set of axis would work but I imagine that would need some rather tricky tuning.
    Sorry about the caps but just making the question clear.
    SO...
    WHICH SOFTWARE SHOULD I BE USING THAT WOULD ENSURE THAT BOTH PATHS ARE CUT PROPORTIONALLY? OR MAYBE ANOTHER WAY OF PUTTING IT WHICH SOFTWARE WOULD BE ABLE TO COPE WITH CUTTING ONE SHAPE ON ONE SIDE AND A CONSIDERABLY DIFFERENT SHAPE ON THE OTHER WITHOUT MAKING ANY ERRORS???
    Many thanks in advance,
    Paul
  1. Replies: 0
    Last Post: 07-09-2007, 04:55 PM
  2. Practical CNC software issues
    By Eric B. in forum Waterjet General Topics
    Last Post: 09-02-2006, 06:05 AM
  3. Shortest path between points? Software?
    By jderou in forum Uncategorised CAM Discussion
    Last Post: 12-22-2005, 11:45 PM
  4. Change - from linear path control to CNC path control
    By Fidibus42 in forum CNC Machine Related Electronics
    Last Post: 12-04-2005, 05:43 PM
  5. 4 Axis EDM software , used to create foam cutting path?
    By bgriggs in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2005, 10:52 AM
