Re: Path Pilot 1.9.4 released
![Quote](images/misc/quote_icon.png)
Originally Posted by
Philbobb
I'm not a G-code expert, but everything I've ever seen has the tool change and height offset on different lines.
Tormach's manual specifically calls out putting them all on the same line (section 7.7.3 in the 1100 manual). The post-processor that I use for HSM Works puts them all on one line.
Tormach
You are strongly advised to put the T~, the M06 and the G43 H~ on one line (block) of code. See G43
for more details.
Example: N191 M06 T3 G43 H3
I suspect that Tormach "strongly advises" this as a best practice, just so you don't forget to do it, and so if you edit the code later on and change the tool number, that you won't forget to change which height offset is applied at the same time. PP show still react in the exact same way, even if the tool change and the height offset are separated by a few lines.
To the OP: I seem to (vaguely) recall having an exact similar problem with PP earlier on. IIRC, shutting down and restarting didn't change anything, and think I ended up just doing a re-install of PP.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
