587,311 active members*
3,681 visitors online*
    Oct 2010
    253
    Path Pilot in VM VirtualBox
    I'm trying to setup Path Pilot on my PC in VM VirtualBox so I can check backplots before walking to the shop. So far so good, got it running but the PP's screen is bigger than the window alotment so the bottom and right of the PP screen is cut off. I've dorked around with it a bit, but can't seem to fix it. Any ideas?
Name:	VM VirtualBox screen shot.JPG
    May 2015
    111
    Re: Path Pilot in VM VirtualBox
    Adam, install the guest options disk. The you can change the video size. It allows the video options.
    Press Ctrl alt x. Then you can /usr/bin/gnome-panel to get to more Linux options
    Chris
  1. Path Pilot HAL Extensions
    By Hadane in forum Tormach PathPilot™
    Last Post: 04-25-2020, 07:50 AM
  2. Path Pilot vs Mach 3
    By Bob La Londe in forum Tormach Personal CNC Mill
    Last Post: 10-12-2015, 07:55 PM
  3. CNC Scanner and Path Pilot
    By RA-Bowtie in forum Tormach PathPilot™
    Last Post: 10-12-2015, 05:31 PM
  4. Welcome to the Path Pilot forum!
    By kstrauss in forum Tormach PathPilot™
    Last Post: 03-13-2015, 01:41 AM
