Re: PathPilot compatible touchscreen (Same model as Tormach touch screen) for $149.99
Originally Posted by
MFchief
One final quibble, it doesn't have a VESA mount setup if you don't want to use the stand. Has two 4 mm threaded holes that are spaced 100mm like VESA but only the two. I have to make a mount for it, but I believe the two screws will be plenty, since it is very light weight.
now, if only you knew someone with a CNC mill, you could make a really cool custom bracket... oh, wait...(wedge)
but seriously? just two mounting points? I doubt weight is an issue, but what about twisting/etc type forces? it is a touch screen after all, there will be fingers poking at it... and it may not always be on the center line of the two mounting points?
thanks to evil talonosi, making me spend money I had not planned on spending, I just picked up the 19" wonder if it is the same non-VESA deal? part of my evil diabolical plans for it involved a vesa style mounting...
the 21.5" is a 16x9 wide screen, how does PP deal with that extra room on the side? just stretch the existing screen? or does it actually put it to good use but spreading things out more?
NOTE:As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists.
