587,143 active members*
5,534 visitors online*
Page 1 of 2 12
Results 1 to 20 of 24
    Aug 2015
    58
    Pathpilot corner probe
    I was wonder why the default corner probe in pathpilot is the bottom left corner? I prefer to use a part zero that corresponds to my fixed jaw, because of how I've set up my soft jaws. I'm by no means an experienced machinist though. I guess my question is just more a curiosity. Is there an advantage to using the bottom left?
    Nov 2005
    218
    Re: Pathpilot corner probe
    I don't really know, but I'm guessing because it matches the axis orientation?
    Aug 2015
    58
    Quote Originally Posted by jcposada View Post
    How do you mean?
    Apr 2011
    720
    I'm not sure either, but I suspect he means that as you move away from that corner into the part all the XYZ numbers are positive.
    Terry
    Aug 2015
    58
    Quote Originally Posted by MFchief View Post
    Terry
    Oh yeah, that makes sense.
    Jul 2016
    140
    Not sure why they chose the South West corner. They have a Y minus subroutine so its not like they couldnt have easily done the corner that way. I never program my origin on the SW corner either. I changed a few lines in the probing and corner probing routines and rotated the corner image in the probe screen. Now I can set the XY origins on the NW corner. I'll probably change it so it sets Z as well, but ran out of time today.
    Attached Thumbnails Attached Thumbnails 21372286_320488321747621_1748165600594624512_n.jpg
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Jun 2016
    26
    Nice sharmstr! Can you please share the details of your hack? Not sure what Tormach was thinking when they programmed this feature... I never reference off the SW corner either, it's a floating point.....
    Cheers
    G
    Apr 2010
    60
    That is cool, love to change mine like that. Is it difficult?
    Apr 2013
    1788
    That's a great change! Could you submit it to Tormach as an improvement request?
    Jul 2016
    140
    Quote Originally Posted by kstrauss View Post
    I just reused their code from the "probe y-, set work origin" button so its not like they cant easily do it. They dont need my code. With that said, I'll send them a feature request. Though, they are working on PP 2.0 which I believe is a rewrite so they probably wont spend the time adding it to 1.9x
    What I'd really like to do is add 2 new buttons on the probing screen. One for the this NW corner change and one for a NW Corner and Z minus routine. I need to figure out their gui first.
    Dozer56: I thought about posting the code changes here, but not sure how Tormach would feel about that. If you PM me your email address, I can send it to you.
    Jul 2016
    140
    Just a thought, but maybe they programmed the SW corner so you can probe the fixed jaw instead of a part? I dont know. But that would be helpful in some situations I guess. Even more reason to have multiple options.
    Apr 2016
    109
    That's cool. There's a lot of room on that screen, it would be nice if they'd just make a square grid with a probe button in each of the 4 corners. Just click on the corner you want to probe from.
    I've recently been forced to probe from multiple corners on a complex project. So really, why not? I know they want to keep the screen simple but it still can be. A square, with the target circle and button in each of the 4 corners. Just click the corner you want.
    Jul 2016
    140
    I've added probing of all 4 corners via keyboard shortcuts. Unlike my other code, this one will keep the default SW corner probing and icon in place. If you used my other code and now you want to use this, its probably easiest to upgrade to v1.9.13 again (to get back to a stock install), then upload the 4 corner probe code: https://github.com/sharmstr/4_Corners_Probe
    I did submit a request to Tormach to add 4 corner probe routines. It hasnt made their feature request list so.....
    Mar 2012
    378
    Thanks Sharm
    Apr 2013
    1788
    When one probes for a round boss or hole centre the only option seems to be to set work offset to zero. To measure the location of features, particularly useful for reverse engineering of irregularly shaped pieces, it would be nice to simply display the location of the centre rather than changing the work offset. There seems to be ample free screen real estate to add the necessary buttons. With the current choices one must change back and forth from G54 to G55 to get the actual coordinates of a feature. Or perhaps I'm missing something obvious...
    Jul 2016
    140
    So similar to find x, y or z on the first tab? That's doable.
    Up until this morning, I didnt know how to add buttons to PP. I've now figured it out and they actually work.
  17. #17
    Apr 2013
    1788
    Exactly. Add buttons to find centre of hole, square boss and round boss and display the coordinates without changing anything.
    I like the G54/G55/etc buttons! There isn't room for G59 P~ so perhaps spread the buttons a little although I worry about accidentally hitting Ref A.
    While discussing a wish list for screen changes, I wish that the tool description were displayed somewhere. Perhaps below the M6G43/ Tool Length/ GO TO G30 buttons?
  18. #18
    Jul 2016
    140
    I'm going to make buttons for G59.x. Its a work in progress.....
  19. #19
    Dec 2008
    5
    I do not use path pilot, but if I am understanding the thread properly, wouldn't this SW corner probe be used to set the corner of the fixed jaw of your vice as zero and then install your material.
  20. #20
    Jul 2016
    140
    Quote Originally Posted by rocklebeau View Post
    I made that assumption below. Its still very limiting. I cant think of many times I've lined my stock up with the edge of the jaw. It doesnt matter at this point. 4 corner probing is on the horizon according to Tormach. I've already added it to mine.
Page 1 of 2 12
  1. Corner Probe Macro
    By MBF Design in forum Fadal
    Last Post: 06-13-2015, 07:19 PM
  2. can you use a probe and mach3 to auto probe a part?
    By skyguynca in forum Uncategorised WoodWorking Machines
    Last Post: 11-28-2013, 01:21 AM
  3. TP-100 Probe - Compare Performance Motion probe to IMService probe
    By dgoddard in forum Digitizing and Laser Digitizing
    Last Post: 04-06-2013, 07:13 PM
  4. Renishaw probe corner measure
    By solidcam2011ls in forum Fanuc
    Last Post: 04-26-2012, 03:16 PM
  5. Super Probe 17 Functions in one probe
    By thegimpster in forum PIC Programing / Design
    Last Post: 01-25-2008, 07:46 PM
