I recently (Couple of months ago) upgraded to Pathpilot on my PCNC 1100. I had used the Mach3 control to do some turning work, holding material in the spindle and turning tools in the vise. Now, I have a job to run for a customer that requires the same process. However, since I have switched to Pathpilot, this was an untested area for me. Now I can't get the G95 (Feed/Rev) command to function. When the machine gets to the point where it is supposed to begin cutting, it just sits there. The book says it should work. Has anyone used their Pathpilot control on a mill as a lathe successfully? I'm pulling my hair out, and I need it to work!
Thanks for any help!
Btw, has anyone used the G96 (Constant Surface Speed) command on their mill? It looks promising, but I need the G95 to work first.
