603,896 active members*
6,234 visitors online*
Results 1 to 7 of 7
    Jan 2016
    12
    PathPilot toolpath?
    machining a part and generated a post from Fusion 360.
    imported the TAP file into PathPilot and it shows a massive "plunge" on Z axis?
    Or am i imagining things? the GCode doesnt reference Z beyond like -0.3 inches
    loaded gcode into GWizard Editor and the simulation there doesnt have this at all? neither does Fusion's CAM
    So i took a chance and I ran the cycle with near zero speeds and it never plunged or followed that line down on Z?
    is this normal?
    May 2015
    111
    Re: PathPilot toolpath?
    Can you post the G Code?
    Jan 2016
    12
    Sure.. here you go
    May 2015
    111
    Looking at the GCode it goes to Z0.193 at f15 then to Z0.0324 at F15. It then plunges to Z-.023 at F5 which all looks normal.
    Not sure why it is displaying this way. I will load it on my mill tomorrow and see what it looks like.
    May 2015
    111
    When I load your program in my Mill this what I get in Side View Mode I did not have the tools the same as you but it looks like it runs ok.
    You might try setting your workpiece z 0 first before loading the program to see what it looks like.
    Attachment 307606
    Jan 2016
    12
    ah, yeah, great point, let me go zero off the workpiece before loading program and try again.
    Jun 2014
    1787
    I ran the program in air, the thing I noticed is the rapid down to the work height was very slow on the initial rapid, after that they seemed OK, I had a couple arc too small warnings, the program did run though, really couldnt tell much as I was cutting air.
    mike sr
  1. PathPilot on Novakon
    By brianbonedoc in forum Novakon
    Last Post: 12-23-2017, 09:25 AM
  2. Digitizing with PathPilot
    By Tbkahuna in forum Tormach PathPilot™
    Last Post: 07-20-2017, 01:46 AM
  3. Will this computer run pathpilot?
    By keen in forum Tormach Personal CNC Mill
    Last Post: 11-02-2015, 09:10 AM
  4. PathPilot kernal for $10
    By johnh in forum Tormach PathPilot™
    Last Post: 07-02-2015, 05:12 PM
  5. PathPilot V1.6
    By adamboon in forum Tormach PathPilot™
    Last Post: 03-26-2015, 12:33 PM
