603,958 active members*
2,280 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > PC Based Hardware Controller Kit Needed
Results 1 to 7 of 7
    May 2004
    I am new to this hobby and would like to build a simple cnc machine. I would though like to purchase the controller as a kit or completed product so I don't have to build it. Is this possible or am I out in left fielf here.
    Jan 2004
    119
    I don't know why the address did not post but check out the 'links' you will find the info there . There are
    numerous suppliers of the types of kits you need.
    hope this helps
    Mar 2003
    35494
    A lot of people use the Xylotex stepper drivers on small machines, http://www.xylotex.com .Some also use Geckos, http://www.geckodrive.com . The machine is actually controlled by software, such as TurboCNC, http://www.dakeng.com , or Mach2, http://www.artofcnc.ca
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Apr 2004
    439
    http://www.embeddedtronics.com/microstep.html looks like a nice setup ifyour good with electronics
    May 2004
    I found an outfit that had 3 steppers and a control card fo $160.00. I'll be danged if I can find it again. Does anyone know the web site?
    Just John
    Apr 2004
    30
    Could it have been www.stepperworld.com?
    Paul F.
    May 2004
    Thanks, I appreciate the help
  1. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  2. Assembling Gecko based controller
    By walter in forum Gecko Drives
    Last Post: 07-19-2005, 10:30 PM
  3. Dsp Based mini cnc controller
    By cncadmin in forum News Announcements
    Last Post: 01-05-2005, 01:59 PM
  4. Speed/Torque Boost on Allegro 5804 Based Controller (???)
    By FrankG in forum Stepper Motors / Drives
    Last Post: 11-28-2004, 03:03 PM
  5. CNC Retrofit - Kit verses turn on and go
    By MetDetect in forum Uncategorised MetalWorking Machines
    Last Post: 07-13-2004, 04:06 AM
