603,946 active members*
3,182 visitors online*
Results 1 to 7 of 7
    Feb 2012
    PC to CNC communication problem
    New to the board, I have a Toro Cut CNC and have been using a floppy disk to transfer data to and from the pc. The floppy drive went out, so I bought a RS232, 25 pin cord to connect the pc to the CNC. The computer won't recognize the CNC this way. Is there any software available that needs to be used to make this work? I checked the pin out and they are correct.
    May 2009
    104
    You could try DNC software. They have a free trial version available.
    After installing you send a program from your machine to the PC and the software senses what settings to use for comm. It also has pin out configurations.
    cnc and dnc software for RS232 CNC program transfer with drip feeding
    That should get you started.
    Good luck,
    Maz
    Dec 2010
    61
    Make sure you enable EPP - Enhanced Parallel Port if not already done so.
    Mar 2003
    2932
    Quote Originally Posted by steeltoes View Post
    Just curious... what does enabling EPP do for RS232 serial communications?
    Mar 2003
    2932
    Quote Originally Posted by shig22 View Post
    If I'm not mistaken, your machine is a Bridgeport Torq-Cut, with a DX-32 control.
    If so, you should be able to send/receive programs with any COMM software, such as NCNet Lite, free from CADEM at DNC – wireless and wired, Free DNC for 1 machine
    The cable appears to be a standard Fanuc-style cable:
    DB25 (CNC) <------------> DB9 (PC)
    1 <------ SHIELD -------- (no connection)
    2 <------------------------> 2
    3 <------------------------> 3
    7 <------------------------> 5
    4&5 jumpered (CNC end only)
    6, 8 & 20 jumpered (CNC end only)
    Dec 2010
    61
    Quote Originally Posted by dcoupar View Post
    My bad I thought you were using a parallel port, EPP enables two way communication. TYo my knowledge a serial port already has two communication, but I'll verify that.
    Mar 2003
    2932
    Yes, a serial port is bi-directional by nature.
  1. communication problem
    By przemekmor in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-05-2011, 09:40 AM
  2. Communication RS-232 problem
    By quasarix in forum Fanuc
    Last Post: 10-15-2010, 12:58 PM
  3. Communication problem with X4+
    By shannow in forum Syil Products
    Last Post: 02-23-2009, 11:43 AM
  4. Communication Problem
    By LEGCNC in forum DNC Problems and Solutions
    Last Post: 05-30-2006, 02:34 AM
  5. Communication Problem
    By Alex S.A in forum Computers / Desktops / Networking
    Last Post: 01-28-2005, 04:38 PM
