587,278 active members*
3,504 visitors online*
IndustryArena Forum > Community Club House > Computer Technology > USB, RS232, PARALLEL etc > PC to CNC devices for older CNCs (RS232 <--> USB)
Results 1 to 5 of 5
    Jan 2015
    3
    We have a couple older Mori-Seiki CNC machines, that just have RS232 inputs. For many years, we've been using a Palm Pilot as a way to get programs off our PC, to the machines.
    I'm looking for a better way to do this, since if the current setup breaks it will be difficult to replace quickly. What I'm imagining is a device that connects to a computer via USB, and can then initiate sending data to a CNC via RS232. Something exactly like this, I think:
    USB Connect External - Shop Floor Automations
    But, $700 seems insane. Anyone know of a cheaper device that accomplishes the same thing?
    Thanks.
    May 2012
    36
    Re: PC to CNC devices for older CNCs (RS232 <--> USB)
    I would recommend to use RS232-to-Ethernet devices like MOXA Nport 5110. They are more stable.
    AGG Software. DNC Precision and CNC Syntax Editor software.
    Jan 2015
    3
    It looks like the Nport is just an adapter, between ethernet and RS232...is that right? I'm looking for something that can hold the data, then initiate the transfer to the CNC machine.
    Feb 2015
    174
    I have several older machines that RS232 and DNC just fine. I use an older 9X operating system simply because they handle ports far better than newer OS's, then a simple procom or bitcom will do the trick, its free
    sorry, new to this forum, ment to respond to alpinems post, get it on the network and move around the code easy
    Feb 2015
    6
    Take a look at this product it works great.
    SOFTWARE AND UPGRADES
  1. Replies: 15
    Last Post: 11-18-2011, 04:45 PM
  2. New to CNCs
    By amcoform in forum Want To Buy...Need help!
    Last Post: 02-11-2011, 10:16 PM
  3. RS232 wiring configuration detection devices
    By Petro in forum Haas Mills
    Last Post: 04-11-2007, 01:27 PM
  4. Network my PC’s with 7 CNCs
    By sas in forum DNC Problems and Solutions
    Last Post: 03-09-2006, 02:48 AM
  5. Four axis CNCs?
    By Zumba in forum Commercial CNC Wood Routers
    Last Post: 12-29-2005, 03:00 PM
